Installing door locks
I thought there was someting in corvettefaq.com that talked about changing out the locks but I can't find it. Any help is appreciated.
Thanks.
Scott
This will give you more room to reach in and remove the linkage from the key lock, and finally the clip that holds it in the door.
It's hard to reach and having a person will small hands to help is a big plus.
Thanks.
Scott
Do you have the new locks in hand? If so look inside the open door cavity and reach for the lock cylinder. You should be able to feel a lock sring clip that fits flush with the door skin. It will have a lip on it. Take a flathead screwdriver and push the lip of the clip away from the cylinder. You might have to hit the screwdriver with a small hammer. After the clip comes off the lock will pull out of it's hole. Hope this helps you.
