damplifier pro
Old Jul 22, 2008 | 07:29 PM
t3hlulzkiller's Avatar
t3hlulzkiller
Default damplifier pro
This stuff seems to be sound deadening + heat insulation, correct?
so I could buy 80sqft of this and do under the carpet from and back of the 'vette and not have to put reflectix?
link: http://www.secondskinaudio.com/vibra...r-pro.php#tab4
Old Jul 22, 2008 | 07:55 PM
Theiskell's Avatar
Theiskell
It looks like it would work, but wow is it pricey
Old Jul 22, 2008 | 08:43 PM
t3hlulzkiller
cheaper than buying dynamat + reflectix
Old Jul 22, 2008 | 09:34 PM
TACatfish#64's Avatar
TACatfish#64
Default I bought some damplifier
It is pretty dense and the AL surface seems pretty thick. I bet the pro is really heavy stuff. It seems to bond well to the bare fiberglass. It is supposed to act as a heat barrier seems like it would. I plan on doubling it up around the tunnel area and under my feet. I seems like a good product and some guys on the Lateral G forum recomended it.
For what it's worth here is one take on underlayment.
http://www.sounddeadenershowdown.com/
Old Jul 23, 2008 | 08:43 AM
Durango_Boy's Avatar
Durango_Boy
Damplifier is a wonderful product well worth the money. The owner Anthony is also a great guy. However, it's just a sound deadening material...just like Dynamat. Is refers to it as a Thermal Acoustic product...which is throwing you off. This type of sound deadener, like Dynamat, turn vibrations into heat energy. The heat is dissipated from under the mat...hence the foil backing. This product will not act as a heat barrier...you'll need jute or Reflectix or a similar product for a heat barrier to go over the Damplifier or Dynamat.
To damplifier pro
