Mancave
Old Jul 23, 2008 | 12:36 PM
...Roger...'s Avatar
...Roger...
Originally Posted by 68 NJConv 454
I would go with pressure treated regardless, cheap insurance to cover the shear cost of the garage along with the fact that the vette and other amenities are inside.
Wonder if that composite stuff would be the best of both worlds? Like Trex. Nonporus, stain resistant, won't rot, still need a skidplate on the jack & jack stands. Probably still cheaper than concrete. hummmm
Composite...thats an idea.It would be pretty slippery but you certainly wouldnt have trouble sliding the jack and stands around.
Old Jul 23, 2008 | 12:41 PM
...Roger...
Originally Posted by Richard454
Just an educated guess- but the wood (w/ concrete at ~$100 cu yd) would be about a third of the cost-comparing my garage (24' X 30').
However, down here (Atlanta) the 2 x 10s would have to be 18" above the ground otherwise they'd have to be pressure treated-which would still be about ½ the cost of concrete.
Sounds like you know some things about building. What about getting it approved for code? Is this an issue in some areas.I know I put up a big shed and the city said if I have a concrete base I have to get a permit but if I build it like his garage(on stands or blocks)I wouldnt need a permit because they consider that temporary.
Old Jul 23, 2008 | 01:47 PM
justaguy10825's Avatar
justaguy10825
I am building a 25'x40' 10' ceiling house for the toys...... The front door is being installed tomorrow... Except for the concrete work & installing the main door, I've done all the work with the help of friends... 1000 sq ft... Twice the size of my first apartment
Old Jul 23, 2008 | 01:48 PM
Boog's Avatar
Boog
Took 29 days working after work and weekends, also helping was air-nailer especially the roofing nailer.
moosie982's Avatar
moosie982
Originally Posted by Boog
I'm sure prices would be different, I think it was about 7 ish, but I did all the work including electrical.
This includes eveything the doors and openers siding roofing etc.
Thank you very much for the reply, you ARE 'effin talented !Peace,,,Moosie
Old Jul 23, 2008 | 01:55 PM
Richard454's Avatar
Richard454
If your permit office is ANYTHING like the ones I deal with- Ask that question a second time and you'll get a different answer. However, "they" are always right!!!
Just a guess- they might limit your so called "shed" to a certain square footage or height.
I just see the termites having a Field day down here in the south.
Nice job- I just use my hammer to pull nails-Air is the only way to go.
Richard
Old Jul 23, 2008 | 04:06 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I really feel like I'm slumming now.
Old Jul 23, 2008 | 04:34 PM
justaguy10825
Going to try this again... The freekin picture keeps coming ou to big... Anyway... Going to be insulating and dry-walling the inside shortly... Have not made any decisions on the floor... Any ideas on an affordable flooring? It is 1000 sq ft building...
Thanks!
Old Jul 23, 2008 | 04:53 PM
68 NJConv 454's Avatar
68 NJConv 454
Most composites offer a "testured" or "grain" look which aids in avoiding a slippery surface. I beleive I also read that one of the companies offered a coating that ensures grip.
I'm researching building a deck on my house so I've been up to my elbows in literature on all the composite products.
I am so jealous of all your garages, my garage is just big enough for the vette and I have to walk sideways to get around it, and its empty, just the vette and a toolbox.
Old Jul 23, 2008 | 05:11 PM
b71vette's Avatar
b71vette
Actually it looks quite different already, I've got a recliner and an lcd tv plus a 1000 watt 7.1 dvd in there now so... I may spend more time in there then is needed.
Now that's my kinda Mancave. I've been wanting to put an LCD in my garage, but I need to replace the rear-projection widescreen in the house with an LCD first. Trying to figure out how to mount the 55" rear-projection on the garage wall. It has a great 1080i picture so I don't want to get rid of it. I'd like to have the LCD 1080p in time for the olympics.
Enjoy your new Mancave
Old Jul 23, 2008 | 05:24 PM
PhyscoVette's Avatar
PhyscoVette
Easy! Build a box base just big enough for the tv then suspend it from the ceiling with chain and position it against the wall.
Old Jul 23, 2008 | 05:44 PM
onaqwst's Avatar
onaqwst
i was thinking.....why didnt boog build the wall and lift them in place...then i remembered that he built it himself.... so that makes sense why you sheeted the walls later.......
i have learned alot of things over the years by doing things myself.....
good work
Old Jul 23, 2008 | 06:51 PM
  #33
stingr69's Avatar
stingr69
These all look great.
I only have a 35' x 13' attached second garage but that one is ALL MINE. I just added a dedicated HVAC system to it so I can work out there year round.
-Mark.
Old Jul 23, 2008 | 08:26 PM
  #34
Boog's Avatar
Boog
good work
I also used heavier than normal sheething on the sides, instead of two piles of sheething I just used roofing sheething everywhere and at 10 feet you're right I'd bust a gut.
Old Jul 23, 2008 | 11:22 PM
  #35
b71vette's Avatar
b71vette
Hey thanks for the great suggestion !!
Old Jul 24, 2008 | 12:05 AM
  #36
stock76's Avatar
stock76
You did a beautiful job on that garage.
Old Jul 24, 2008 | 08:32 AM
  #37
OURSHARK's Avatar
OURSHARK
Very nice garage. I have a two car garage attached to the house it is just not big enough.
To Mancave
Old Jul 24, 2008 | 10:05 AM
  #38
Boog's Avatar
Boog
Old one was more like a real doghouse, easy to move though.
Old Jul 24, 2008 | 10:07 AM
  #39
Vampyre's Avatar
Vampyre
Very nice... Wish I had that much room!!!
Old Jul 24, 2008 | 04:15 PM
  #40
V77Vette's Avatar
V77Vette
yea i would take your old one
