Air Dam
Old Jul 23, 2008 | 07:39 AM
NBC3's Avatar
NBC3
Default Air Dam
Hi folks
Here's another question for you. My car seems to float a bit at high speeds (90 to 100 mph). Would a bigger air dam or spoiler in front give me more positive steering? If I was to buy a spoiler and have it painted, is it a pita to intsall?
Thanks!
Old Jul 23, 2008 | 08:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A larger spoiler would create a bit more downforce on the nose. Steering may get better and cooling would probably improve a little, but how much 90-100 mph cruising do you do? At speed, the nose tends to lift on all C3s. The 80-82 noses are marginally better, but not optimum. Second consideration is under car clearance for the larger spoiler. Folks tend to whack them on things.
If you go with the install, I wouldn't go any bigger than the 78 Pace Car chin. 78-79 assembly instruction manual shows the installation.
Old Jul 23, 2008 | 08:30 AM
rihwoods's Avatar
rihwoods
Drop front end !" and add an 3" extension to existing spoiler...I used piece cut from plastic garden boundary material...bumps,scrapes don't hurt it...
Old Jul 23, 2008 | 09:03 AM
Attfay Elleybay's Avatar
Attfay Elleybay
My 1st vette did the same thing. The stock hood seems to trap air. The vette I have now has a 2-3" hoodscoop that seems to help. I think it lets the air escape.
Old Jul 23, 2008 | 01:18 PM
Jay-Dog's Avatar
Jay-Dog
My 76 air dam was missing so I just finished installing the stock piece with a 4" additional piece of aluminum. It is approx 5" off ground. Haven't driven the car much since installation. I simply painted it black. You really wouldn't know it was even there. I wouldn't expect it to help much with lift and a feeling of wandering or floating. I think that's just too much of a symptom of the overall body design. I'll post pix some time.
Jay
Old Jul 23, 2008 | 03:43 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
You could add an air dam and that would work, but you could also lower the front of the car and put a slight rake into it. I have a 76 with an 80 rear end (don't know how much this helps .... I originally did if for appearance years ago) and the front end is lowered so that the car sits at a rake. I've been up to 115-120 mph quite a few times on a road coarse with no noticable float to the car.
Either method should work, just go with the one that suites your taste the best.
Old Jul 23, 2008 | 07:55 PM
Paul L's Avatar
Paul L
Rich,
Great innovation! I like it. And yes I just finished doing some gardening using that product!
Old Jul 23, 2008 | 08:33 PM
outlawkinser's Avatar
outlawkinser
When I bought my '74 in 1977 I experienced the same situation and installed a '78 Pace Car Front Spoiler. That took care of it.
Mike
To Air Dam
