Ok, so I'm new to the whole C3 scene (C4 guy) but I'm searching for a chrome bumper car these days. I keep reading that 1970 was the last year for high compression engines. Well, what is the octane requirement for these 1970 and earlier cars? Do they require special fuel that I wont be able to find at a present day pump? My town only has up to 92 so it is a concern. Also, what octane do the post 1971 cars require? Do the 1970 (and earlier) cars require a modification to the carb in order to run unleaded fuel? I've searched a good bit and can't find these answers. Any help you can provide would be greatly appreciated.
74 and up C3s have hardened valve seats and will run on cheapo no-lead. They like 91 octane, but they'll run on 87. The earlier cars were designed for leaded fuels and higher octanes but will run on no-lead. My '68 has stock heads and 10:1 compression; she runs okay on no lead. Periodically, I run a can a lead subsistute with a fill up.
You have genuine concerns when you go to the super horsepower cars (L-88, etc) designed to run on 104 leaded.
I believe the compression ratio for 1970 and earlier is from 10.5:1 to 11:0:1 except for the extreme engines like the ZL-1 and L-88.
In any case my 1972 454 runs fine with absolutley no pinging on 87 octane because the compression ratio is 8.5:1. I'm pretty sure the 1971 is also 8.5:1.
No modifications to the carburetor are necessary to run unleaded but from 1971 on, the cars were designed to run on lower octane unleaded fuel.
I always run premium in both cars 71 & 72 ,350 base with 8.5:1 .I also pour in a bottle of NOS (cost about $10) It raises 6 full numbers (60 pts) Runs like a champ, no hes, no ping
