I took out my power antenna and just put a mast antenna in.
Now these mast antennas are for steel body cars and would ground at the nut or do they have to? so my question is....
Where the antenna nut holds the antenna to the body do I have to make up some sort of ground wire and hook it to the frame this being fiberglass car. And could this be why I have had so much static on the radio?
The power antenna had a ground wire in the harness or am i wrong?
as for the mast antenna they are all made for steel body's thats were they get there ground .....i think...
I think I'm correct in saying that you need a ground plane at the base of the antenna. Not sure of the theory behind this but the same applies to fibreglass boats. Ecklers have a Ground Support Plate. you then have to ground the plate via a ground strap. This is not to supply an earth for the motor to work, it's to do with reception properties of the antenna.
I don't have any pics handy but the mast antenna on my 72 had a plate attached and was grounded to the frame. Any electrical circuit normally has a ground connection (or it wouldn't be a circuit )and for Vettes it has to be the frame or a circuit that is connected to the frame. Fiberglass isn't one of your better electrical conductors.
As mentioned, the ground strap on the power antenna was to help reception, not operate the power antenna.
And all the vendor catalogs list the ground plate used with the stationary mast.
In short, ground it.
To quote Wikipedia, and this is just a small exerpt from a longer explanation......... Essentially, the ground plane acts as the "missing half" of a dipole two element, half wave long, center fed antenna. It can be thought of as the "return current" path for the radiating antenna.
