Wire Coverings.....
Old Jul 28, 2008 | 10:14 PM
Richard Cooper's Avatar
Richard Cooper
Default Wire Coverings.....
I am looking to cover up the wires in my engine bay and make it look a little neater in there. What are some of you guys using to do this? Is there any new stuff out there for this purpose?Thanks in advance.
Old Jul 28, 2008 | 10:17 PM
TPI BOY's Avatar
TPI BOY
Old Jul 28, 2008 | 11:17 PM
SIXFOOTER's Avatar
SIXFOOTER
BlinG!!!
http://cableorganizer.com/convoshield/
Old Jul 29, 2008 | 09:23 AM
PETKAH's Avatar
PETKAH
Try Sumit they have a variety of items. Also, sometimes local parts stores - Pep Boys/etc have some.
Old Jul 29, 2008 | 10:08 AM
CTVETTE78's Avatar
CTVETTE78
Automotive wire loom (the split convoluted tubing you see under the hood of most cars) is available in most auto parts stores. If you need a lot, try Waytek Wire
(www.waytekwire.com)
You can get special T fittings and end fittings to give your installation a finished look. Use heat shrink tubing on the ends where you can, (you have to disconnect the wires to slide the tubing on) and electrical tape where you can't use heat shrink tubing.
Good luck! It's a worthwhile project that will really clean up the look of your engine bay, and won't cost much to do.
Rich
To Wire Coverings.....
