Fuel question on high compression C3s
Old Aug 4, 2008 | 01:39 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Default Fuel question on high compression C3s
Hey all:
Back when I had my '69 (sold it in '96), I was still able to occasionally find leaded fuel, but it was pretty much gone around here by then. I used to go to Sunoco, where they would have 100 octane "racing fuel", put a couple of gallons of that stuff in there, then fill up with the 94 octane "ultra". That would make that car purr like a kitten at idle and growl like a lion when stomped on. My question is, I haven't seen leaded fuel or the racing fuel in well over a decade, so what I was using before is not an option. What are you guys and ladies using for fuel? Where do you get it (if it is anywhere other than the local gas station)? How much do you spend on it?
Thanks,
PK
Old Aug 4, 2008 | 05:43 PM
Ironcross's Avatar
Ironcross
I use 94 in these engines. 1970 LT1, 1966 L72 and a 67 L78 all tuned to the max. No addatives either, they dont work anyway....
Old Aug 4, 2008 | 05:47 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
cam2 110 $8.99 a gallon though
Old Aug 4, 2008 | 08:04 PM
C3 Stroker's Avatar
C3 Stroker
Sunoco Ultra 94 (93 works OK, too)...10.4 compresson SB 427. Also in a 10.9 C.R. 383.
Old Aug 4, 2008 | 08:28 PM
Scott Marzahl's Avatar
Scott Marzahl
Premium fuel for our 10.25:1 motors, no additives and 110 leaded racing is plentiful at $9/gallon if you need it.
Old Aug 5, 2008 | 08:41 AM
Derrick Reynolds
Great, thanks!
I haven't seen racing fuel around here in forever, but I admit I haven't exactly been looking while driving my '95 Camry.
Old Aug 5, 2008 | 08:52 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Any local tracks, drag or roadracing will have racing fuel. Other than that look for Cam2
Old Aug 5, 2008 | 09:33 PM
Ironcross's Avatar
Ironcross
unless your ultra high compression 93-94 is all you need. Cam2 or its equivalent is just a waste of money.....
Old Aug 5, 2008 | 09:36 PM
nomrlz's Avatar
nomrlz
i've always just used 93 in my street motors. anything really high compression gets the race stuff
To Fuel question on high compression C3s
