Pushrods?
Old Aug 6, 2008 | 09:28 AM
Pretty Will's Avatar
Pretty Will
Default Pushrods?
Im looking at summit heads http://store.summitracing.com/partde...art=SUM-152123
and this cam
http://store.summitracing.com/partde...rt=LUN-60103LK
Not sure what length pushrods I need.
Old Aug 6, 2008 | 09:31 AM
Vette79C3's Avatar
Vette79C3
Stock pushrod length for a 79 was 7.800. I recommend purchasing a pushrod checker tool and then measure after installation of heads, lifters and rockers to be sure.
Old Aug 6, 2008 | 09:45 AM
Pretty Will
It si not an original engine it is a gm performance replacement.
This is it
http://store.summitracing.com/partde...3&autoview=sku
Old Aug 6, 2008 | 09:54 AM
Vette79C3's Avatar
Vette79C3
Have you asked Summit for assistance?
Old Aug 6, 2008 | 09:59 AM
Pretty Will
Yea i just got off the phone with the guy and he said that stock length should work, thats the problem I have no idea about the lengths.
Old Aug 6, 2008 | 10:09 AM
Edzred72's Avatar
Edzred72
With a hardened, .080 wall thickness, one piece push rod, ya can't go wrong.
Eddie
Old Aug 6, 2008 | 10:29 AM
Pretty Will
what about diameter? 3/8 5/16?
Old Aug 6, 2008 | 02:43 PM
thegazman's Avatar
thegazman
Default thegazman
Are you installing roller rockers? If so, you will need to follow Vette79C-3's advice, use a push rod lenght checker prior to buying new push rods. Plus you need to be sure the push rod ends match the size of the recess on the end of your rockers.
Old Aug 6, 2008 | 05:18 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
diameter will depend on your rockers. Don't skimp here...I tried cheap Comp Cams pushrods once. Bent one on the way to a friends wedding. I was so pissed! Replaced them with Trick-flow 1 piece hardened push rods. Problem solved.
Old Aug 6, 2008 | 07:02 PM
b71vette's Avatar
b71vette
this is definitely sound advice, I know from experience. fortunately I was able to return a set of the wrong length pus hrods. roller rocker arm geometry varies from mfg to mfg. I changed from 1.6 ratio Cat Power Rocker to 1.6 ratio Scorpion and had to go to a stock plus .250 pushrod. Comp sells a decent push rod length checker. I believe Comp Cams website has a tech doc on how to go about checking pushrod length with the tool.
Old Aug 7, 2008 | 08:21 AM
Pretty Will
I think i am in pretty good shape now, I went ahead and ordered the trick flow one piece rods and a set of full roller rockers. thanks for the info guys, big help.
To Pushrods?
