Sidepipe mounting hardware
Old Aug 9, 2008 | 03:59 PM
addballer696's Avatar
addballer696
Default Sidepipe mounting hardware
Im looking into buying some used hooker sidepipes and headers, but they dont come with any mouting hardware to put them on. I have been looking online and I can't seem to find just the hardware as a kit for sale. Any suggestions of where to find this, or do you think I can mount them with bolts ect. that I find locally.
Old Aug 9, 2008 | 05:03 PM
Durango_Boy's Avatar
Durango_Boy
Call Hooker directly, or someone like Mid America. I know that can sell just the hardware but they may not list it. If you call them, you can ask them for hardware only, and see where that gets you.
Matt
Old Aug 9, 2008 | 05:17 PM
addballer696
thanks, ill give um call if I end up wining the sidepipes
Old Aug 9, 2008 | 05:26 PM
Durango_Boy
If you win them and need some install tips just let me know. I have put side pipes on two '77 Vettes and a local friend and I just swapped some old side pipes for some new ones on his '74.
Every install is different but I might be able to give you a few pointers.
Old Aug 9, 2008 | 05:28 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I went through this same thing myself.
call your local Hooker retailer and have them order the sidepipe hardware install kit.
I can probably find the P/N if you need it but I wont be able to get it till Sunday
Old Aug 9, 2008 | 05:51 PM
aworks's Avatar
aworks
You can buy the hardware from Summit. I just bought a few sets to keep in stock.
Old Aug 9, 2008 | 05:55 PM
chris75stingray's Avatar
chris75stingray
i just used a nut and bolt and washers. i was a PITA to get the bolt inside the rail and through the hole but i did it. if i ever have to pull them off i think i will buy the right hardware though.
Old Aug 9, 2008 | 07:37 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Mine did not line up with the slots in the frame as they should, and I was forced to use regular nuts and bolts with washers, etc. It worked just fine.
Old Aug 9, 2008 | 10:41 PM
addballer696
im running on a real tight budget, and have a lot of bolts and nuts laying around, so i think i'll try that first and then get the real hardware if i need to.
Thanks for all the help everyone
Old Aug 10, 2008 | 12:25 AM
BSiegPaint's Avatar
BSiegPaint
PM me your mailing address - I have a s**tton of the carriage bolts I used on my install left over and I'll send you some.
To Sidepipe mounting hardware
