key stuck in ignition...
Old Aug 15, 2008 | 09:32 PM
the3car's Avatar
the3car
7th Gear
Default key stuck in ignition...
key is stuck in the ignition. i'm able to turn it back past acc spot, but not far enough to remove key. any ideas? thanks
Old Aug 15, 2008 | 09:55 PM
tnovot's Avatar
tnovot
Amazing! I'll be watching this post withy great interest. Same thing with my '75 the other day after R&R rag joint to align flats on steering shaft and steering box. I was getting ready to post a similar question.
I can turn the key back to Acc. but only part way back to Lock.
Terry
Old Aug 15, 2008 | 09:58 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Reverse Lockout not engaged completely, if it is dissconnected you still must have the column completely rotated to remove the key.
69VETT
Old Aug 15, 2008 | 10:10 PM
luerja's Avatar
luerja
Look inside the firewall area near the column and connected to the steering column is a lever connected to a steel cable leading to your transmission.... push that up or down and your key will come loss... have two people unless you want to run back and fourth
Old Aug 15, 2008 | 10:47 PM
the3car's Avatar
the3car
7th Gear
THAT'S WHY THESE FORUMS ROCK! that was it. the cotterpin was gone, and the cable was disconnected. key out. THANKS!
Old Aug 16, 2008 | 06:25 PM
luerja's Avatar
luerja
EXCELLENT I knew your issue because it happened to me too and someone else helped me out the same way... Yes this forum ROCKS!
Old Aug 16, 2008 | 09:36 PM
tnovot's Avatar
tnovot
Got my key out also. Many thanx to the3car for the original post and to 69Vett and luerja for the help.
Terry
Old Aug 27, 2008 | 02:30 PM
blue78vette's Avatar
blue78vette
1st Gear
Default 78 Key Stuck In Ignition
The key to my 78 is stuck in the ignition also. I have an A/T. I am having problems finding the magical lever i need to help release the key. I have looked both inside the firewall and under the brake booster, but I cannot find it. Any photos or more help would be greatly appreciated.
Old Aug 27, 2008 | 06:33 PM
luerja's Avatar
luerja
I am trying to find you a picture it's proving to be difficult. It is there i promise. It might be easier to jack the car up where you can safely go under it and look upwards. it is the first thing out of the firewall thats attached to the column and will be pointing towards the engine.
Old Aug 27, 2008 | 06:53 PM
69Vett's Avatar
69Vett
follow the steering column coming out of the firewall on the engine side,
there will be an arm/lever about 4" ? long very close to the firewall.
the cable moves the arm up and down to lock/unlock,
this movement transfers into a slight rotation of the column.
which locks/unlocks the key release part of the column.
your cable may be missing, if so the arm will have about 1/4" hole in it where the cable should attach.
Often people remove this and do not secure into the unlock position,
after it gets driven the vibrations allow the column to rotate,
and all of a sudden, you can't get your key out !
Old Aug 27, 2008 | 10:02 PM
dobroman2001's Avatar
dobroman2001
Here's a picture off of my '76... you can see that I have the cable disconnected from the bracket. I was in the process of removing the Steering column.
http://s189.photobucket.com/albums/z...withoneend.jpg
Old Aug 28, 2008 | 09:42 AM
Jim Shea's Avatar
Jim Shea
The cable lockout system was only used from 1969 through 1976. 1977 through 1982 used a small lever (called a finger inhibitor) right behind the ignition key/lock cylinder. You need to lift (or depress) the lever with your finger in order to rotate your ignition key from OFF to OFF-LOCK.
Just as a point of information. The ignition key sequence is as follows:
START, RUN, OFF, OFF-LOCK, & ACCESSORY.
You can always turn your engine off by rotating your ignition key CCW from RUN to OFF (but this position does not lock your steering wheel.)
With the 69-76 system you had to shift into REVERSE (manual shift) or into PARK (automatic trans) in order to rotate your ignition key further CCW from OFF to OFF-LOCK.
With the 77-82 system you have to actuate the finger inhibitor in order to be able to reach OFF-LOCK.
BTW, the earlier cable system (1969-76) locks the shifter as well as the steering wheel. The 1977-82 system only locks the steering wheel.
Hope that this helps,
Jim
Old Aug 28, 2008 | 09:24 PM
tnovot's Avatar
tnovot
I am really amazed at so much great info here about this topic. I have been a car guy and gearhead for almost 50 years and I can't believe I never knew about this. I have some experience with C1's and C4's but am still pretty new to the C3's.
Terry
Old Aug 28, 2008 | 09:37 PM
luerja's Avatar
luerja
Jim
Where the heck you been Jim... I have been waiting for you to chime in and correct my errors and bail me out of this
Jim Shea is your man....when he responds you better listen
Thanks Jim for chiming in!
Old Aug 28, 2008 | 10:18 PM
Jim Shea's Avatar
Jim Shea
Last week I was on the Norwegian Star, cruising to Alaska with family and friends.
Internet on the ship was like 40 cents per minute. So I took a break from the internet for a week.
Still a bit jet lagged (4 hours difference from Michigan to Alaska) but I'm back.
Jim
Old Jan 30, 2009 | 02:16 PM
SpE3dF0x's Avatar
SpE3dF0x
How do you take out the ignition from the steering column?
Old Jan 30, 2009 | 04:56 PM
Jim Shea's Avatar
Jim Shea
Point of information. Before 1969 all GM passenger cars had the ignition lock cylinder and the ignition switch mounted in the dash. Starting in 1969 the ignition lock cylinder was moved to the steering column head. The ignition switch was moved so that it was mounted on top of the steering column jacket down under the dash. More work to service it -- more difficult for a thief to steal.
If you want to replace the ignition lock cylinder you need to remove the steering wheel, the locking plate, and pull the turn signal switch far enough out of the steering column head so that you have access to a small tab that needs to be depressed. With the tab depressed, the lock cylinder should pull right out.
There are instructions posted at www.corvettefaq.com
Click on Jim Shea's Steering Papers
Click on Corvette Steering Papers
Scroll down to the type of steering column that you have in your car:
Scroll down to the Tilt & Telescoping Disassembly & Repair Section
or scroll down to the Standard (non-adjustable) D&R Section
Down load Paper #1 and Pic #1 for the appropriate steering column type.
You only need to beg, purchase, or borrow two special tools. You need a steering wheel hub puller. You also need the special lock plate compressor tool to be able to remove the locking plate.
Good luck,
Jim shea
Old Jan 30, 2009 | 05:48 PM
Mikey74Stingray's Avatar
Mikey74Stingray
Mine was getting stuck. I just disconnected the cable from the lever and tied the lever up with some wire.
To key stuck in ignition...
