Side pipes and Headers
Old Aug 16, 2008 | 02:57 PM
BARRY L-48's Avatar
BARRY L-48
Default Side pipes and Headers
I am thinking about putting headers and side pipes on my 80 coupe,is this alot of work or is it fairly easy? I would think the hard part would be installing the headers,any thoughts?
Old Aug 16, 2008 | 04:10 PM
Durango_Boy's Avatar
Durango_Boy
I have done side pipes to two of my three C3s, and I have helped a local guy replace his side pipes. To be honest the hardest part is paying the bill.
The next hardest part is getting all the old exhaust removed.
Once you get the nose 20" up on jack stands, and get the headers in...the pipes are relatively easy. You MIGHT have to notch or or both...or neither, of the rocker covers.
Overall it's something that you and a buddy can do in a few hours if you're prepared and have cold beer on hand.
Old Aug 16, 2008 | 05:27 PM
BARRY L-48's Avatar
BARRY L-48
Sounds like that will be in my future,thanks for the info!
Old Aug 16, 2008 | 05:49 PM
HT1663WB's Avatar
HT1663WB
I installed them on my 77/L48 4 speed a little over a month ago. Took about 3 hours was a pretty easy mod. Well worth it
Good Luck
Old Aug 16, 2008 | 09:51 PM
'71VetteRacer's Avatar
'71VetteRacer
Yes, the hardest part is the bill, but I think the second hardest part is sliding that darned side valance trim piece in.....I still haven't gotten it done on mine!
Old Aug 16, 2008 | 10:44 PM
redman76's Avatar
redman76
St. Jude Donor '09
Hardest part for me was getting the rocker panels off; those screws were pretty rusty. Had one snap off that I had to drill out and retap. It took me longer than 3 hours, but I probably drink more beer than some of the other guys
By far the best mod I've done. Once you get over the $$$ shock, you're going to love them. What setup are you looking to install?
Old Aug 17, 2008 | 10:11 AM
Durango_Boy
You slide the rocker covers in with the pipes installed but loosely bolted so they move. That'll usually give you room for a towel to guard the paint, and enough room to slide the cover in, and get it in position. From there you tighten the bolts that hole the pipes, and you're done.
This is also where you'll find out if you need to notch the cover or not for the collector tubes.
To Side pipes and Headers
