Por-20
POR-20 seems like a good alternative.
anybody have any history using it? photos even?
TIA
I have about 5-6 hours on the motor,
so far no discoloration.
Time will tell, ..... 69VETT
I have also used the Jet-Hot and highly recommend it.
I have tried numerous POR products on various automotive and non-automotive applications with very mixed results. First you have to make sure you follow the directions very, VERY carefully or the product will fail prematurely. In some cases like rebuilding/repairing floorboards which are weakened it worked fabulously...on coating exterior brass lights on my house it worked really well for 3-4 years then failed. (went from brass to black lights after that one!).On non heat related, restorative applications, I would opt for Eastwood's products over POR's. They are a lot less finicky and don't require the prep work or expense that POR's do. I did the ultimate rust test on my 1999 Expedition trailer-hitch with Eastwood's Rust Encapsulator and Chassis black. For prep, all I did was take a wire brush to knock off the loose rust and wipe it down with lacquer thinner. Sprayed it with the Rust Encapsulator, let it dry (I did not follow the instructions as I was in a hurry so I only let it dry for an hour or so) and resprayed it with Chassis Black. It's been over 7 years (maybe closer to 10) and the damn thing still looks perfect!!
