I took plastic food containers and drilled holes in the tops & sides & then filled them with Irish Spring shavings, moth *****, and a dryer sheet, & then placed in the trunk of each car.
In addition, about once a month I scatter moth ***** around the floor.
So this morning I go out and remove the cover from my Prowler to drive it, & off runs a rabbit! Go figure...
I tried the decon traps and they kept eating away at the wiring harness and seat insulation in one of my Camaros. Put some mothballs in a couple of plastic spray can caps and set them inside and under the hood and havent had a problem since.
