Vader Vette
Old Aug 21, 2008 | 11:13 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Can anybody or everybody tell me why I should run my plug wires under the manifolds .I did the motor mounts recently and took the wires out of the MM I want to run them from the top . Was there a reason other than not seeing them that made chevy put them under the manifold and are there any draw backs to running them this way(on top) what boot did everyone use, straight in or some angles and some straight?
Old Aug 21, 2008 | 11:30 AM
Durango_Boy's Avatar
Durango_Boy
They did them under because it's a lot harder to run wires over manifolds than it is headers. With headers you have more options for routing them in a way that they don't get too close. With manifolds it's just harder to keep the distance.
I think I would go with straight boots to try and get out as far away from the block as you can.
Old Aug 21, 2008 | 11:33 AM
Scott Marzahl's Avatar
Scott Marzahl
For me, running them as installed from GM makes for a cleaner looking installation. Nothing distracts from the look of an engine bay then wires running everywhere. If you run from the top use some nice looking looms, the street rod suppliers have some very nice ones.
Old Aug 21, 2008 | 11:56 AM
Lon Wayne's Avatar
Lon Wayne
Thats what Ive been thinking.Ill post some pics when Im done .
Old Aug 21, 2008 | 12:08 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Ive been looking for the best looking wire holders at Jegs And Summit they all seem so generic Ive not found any I really like .Any ideas?
Old Aug 21, 2008 | 12:20 PM
toddalin's Avatar
toddalin
Simple, clean, and effective. Running over the top of the engine results in the shortest plug wires = most current transfered.
One reason GM ran them under the manifolds was for the the radio suppression shields that would be harder to fit (and more conspicuous) over the top.
Old Aug 21, 2008 | 04:08 PM
Lon Wayne's Avatar
Lon Wayne
Man that sure looks good thats what Im talking about doing right there thanks for the pic.Clean engine bay.Looks Marvelous.
Is that A flex fan ? Just put one on my car .It sure is easier to drive on hot days. cools my hole engine area down.
Old Aug 21, 2008 | 04:35 PM
toddalin's Avatar
toddalin
Thanks, yes it's a Hayden 7-blade flex fan.
Old Aug 21, 2008 | 04:58 PM
69monzacpe's Avatar
69monzacpe
I have the stock ram horn manifolds, and run straight plug boots over anodized aluminum supports. Just another option if your interested.
To Vader Vette
