interior gauge lights not working again, help please
Old Aug 23, 2008 | 12:19 PM
capecorvette's Avatar
capecorvette
Default interior gauge lights not working again, help please
man this is staring to get me torked! my fuses are fine, but my interior gauge lights don't work. they did work a week ago. i did removed my speedo/tach cluster to replace my wiper switch but i didn't do anything else. although, i did pull out gauges again and i saw 2 crossed copper connectors where the main plug snaps in, but i corrected it and they still don't work.
any ideas?
thanks
Old Aug 23, 2008 | 12:20 PM
capecorvette
forgot to say car is a 79
Old Aug 23, 2008 | 02:18 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Just A thought the ground wire to the harness might have come un-plugged when you were putting in the speedo parts .I worked on my ft & Bk bumpers once ,they came out great but my tailights didnt work right after the repair so I cleaned up the ground and everything worked great. it always something....Try running A seperate piece of wire from ground to the back of the light housing and if the pop on you have found the Problem.
Old Aug 23, 2008 | 02:34 PM
capecorvette
that could be it, do you remember where this ground wire is? is it part of the harness?
thanks
Old Aug 23, 2008 | 02:48 PM
...Roger...'s Avatar
...Roger...
Are all your instrument lights out or just the ones in the tach and speedo?
Old Aug 23, 2008 | 07:24 PM
capecorvette
all are out
Old Aug 23, 2008 | 07:40 PM
...Roger...
I know you said the fuses were ok but sometimes they look good but their not.Check both sides of the inst. lamp fuse with a test light or voltmeter with the headlight switch pulled out.
Old Aug 24, 2008 | 01:14 AM
hdpete98's Avatar
hdpete98
The headlight switch can cause this. it might need replaced.
Old Aug 24, 2008 | 08:02 AM
...Roger...
Thats correct but thats an easy check because the headlight switch FEEDS the "inst. light fuse".To check just turn headlights on and check the inst. fuse for voltage(rotate rheostat).As you rotate the rheostat you will see the voltage at the inst. fuse go up and down.
Old Aug 24, 2008 | 08:29 AM
capecorvette
car has a brand new light switch. where is this ground that goes to the lights that i can check or make a new one?
Old Aug 24, 2008 | 08:56 AM
...Roger...
Left hinge pillar above courtesy light.Does the light in your shifter light up...what about the light in the wiper switch?
To interior gauge lights not working again, help please
