Welder?
Old Aug 24, 2008 | 10:13 PM
Skyhigh82's Avatar
Skyhigh82
Default Welder?
Millermatic® 140 with Auto-Set...welds 24 gauge - 3/16 in
Requires 1-Phase power
115 V, 20 Amps 60Hz
Millermatic® 180 with Auto-Set...welds 24 gauge - 5/16 in
Requires 1-Phase Power
230 V, 21.7 A, 60 Hz
Which would be better as for electrical usage? 180 is about $100 more than 140.
Old Aug 25, 2008 | 06:21 AM
Gordonm's Avatar
Gordonm
I would go with the 180. You never have enough power. If you go with the 140 you will be running it closer to its maximum a lot. The 180 will be a better machine for the extra 100. Wiring it in is not a big deal if you do not have 230 in the garage.
Old Aug 25, 2008 | 06:41 AM
stingr69's Avatar
stingr69
I have the 140 and it is a sweet machine. More power is definately better but I have never needed more than I have so far.
-Mark.
Old Aug 25, 2008 | 06:42 AM
V-Twin's Avatar
V-Twin
Get the 180
Old Aug 25, 2008 | 07:03 AM
gator79's Avatar
gator79
get the 180 I have one and love it
Old Aug 25, 2008 | 08:21 AM
dstaley's Avatar
dstaley
Go for the 180, no question. You can always turn it down, and big welders run just fine on low power settings.
The larger machines start the weld more smoothly, last longer, don't overheat as easily, have a better quality arc, and of course can weld thicker material. You can get the penetration you need with a 220V machine that a 110V machine simply is not capable of.
For $100 it's a no-brainer. Get the 220V machine.
To Welder?
