starter solenoid
Old Sep 4, 2008 | 07:46 AM
baxsom's Avatar
baxsom
Default starter solenoid
dumb question,
Please keep in mind this is my first chevy. On my 68 mustang the starter solenoid is on the firewall by the battery so its easy to hook up my remote starter switch.
it would be a lot easier to bump the starter if i could hook up my remote and not use the key if i knew where to hook it up to.
Old Sep 4, 2008 | 07:55 AM
...Roger...'s Avatar
...Roger...
Small "S" terminal (one with purple wire)and large pos. battery term.
Old Sep 4, 2008 | 07:18 PM
baxsom's Avatar
baxsom
thanks
now i just need to be able to get far enough under the car to reach the starter
Old Sep 4, 2008 | 08:05 PM
tnovot's Avatar
tnovot
Originally Posted by baxsom
thanks
Of course, you'll want to make sure that your neutral safety switch is working properly.
Terry
Old Sep 4, 2008 | 09:13 PM
Binnie77's Avatar
Binnie77
Terry
The remote switch would be bypassing the neutral safety switch wouldn't it Terry? I don't think it would come into play with direct connections on the two terminals.
Old Sep 4, 2008 | 10:15 PM
SIXFOOTER's Avatar
SIXFOOTER
You can access the purple wire via the white connector behind the passenger side valve cover. Poke a wire in the back side of the connector on the purple wire and put 12v to it there. You can get a Starter Bump switch at some auto parts places or make one with a simple push button from Radio Shack.
Old Sep 5, 2008 | 08:13 AM
baxsom's Avatar
baxsom
thats awesome. i need to go looking for a wire.
got the remote. those are wonderful when you are trying to find TDC on a plug and have no one to bump the key for you.
Old Sep 5, 2008 | 08:25 AM
...Roger...
Not sure of your year but if its one of the older ones you wont have a plug at the back of cylinder head.If your careful you can find the purple going down to the starter and push a sharp probe into the purple to use to connect one lead of your remote starter.Other end can go to large pos. connector (red wire)on back of alternator.
Old Sep 5, 2008 | 08:57 PM
tnovot's Avatar
tnovot
Yep, that's right. What was I thinking? I should have cautioned against having the car in gear when using the remote start. I had one crash into my work bench doing that. Duh, what was I thinking?
Terry
To starter solenoid
