How to safely dimple a header
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Is there a "safe" way to slightly add a small dent to a header tube (ceramic coated) for additional clearance without damaging the coating?
I hear people using a wrench sockets for that, I think you have to use a large one and tap it only enough to do the dent. I got a set of coated headers where the PO did some dents on them, it doesn't show any damage to the ceramic surface at all.
what if you take 2 ball pein hammers and turn one with the ball down against the header where you want the dimple then take the other one and tap the flat face of the hammer untill you get the dimple you want
I respectfully advise against smashing two hammers together. That would be a very good way to send small pieces of metal towards your eyes and face.
Terry
Exactly what I meant I don`t think that the hammer face is hardened to the point that it will chip that easily. I doubt that most commercial ball pein hammers are much over a Rockwell C 40 to 50. If they were hardened to the point of chipping that easily they would be totally useless as a hammer. NOW files and chisels are an entirely different matter.
I put a few layers of masking tape over the area first then used the two hammer method. The one against the header was a non mar plastic mallet. Seemed to work fine & didn't damage the ceramic coating
Jim
Jim
I have personally never done it but I have heard of wrapping the header tube and a socket of the required size and using a press to apply the pressure. This way no possibility of chipping the coating. It might be worth a try. How many times have you seen a "dimple" in a header that has broken the coating and looks nasty?
