Not Too Technical - But Who Knows?
Old Sep 11, 2008 | 09:15 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default Not Too Technical - But Who Knows?
Curious if I can swap doors between a 1977 Coupe and a 1974 Convertible? Anyone out there got any idea how to tell? I can change out the interior panels, not a problem, but what about those doors?
If you knew what I was thinking you would probably just laugh, so don't ask.
Let me know what you think you know please.
Thanks.
David
Old Sep 11, 2008 | 10:25 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I was right, nobody knows this one...
Is there a prize for stump the forum?
David
Old Sep 11, 2008 | 10:45 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
OK, It looks like the doors were the same from 1969-1982 no matter coupe or vert http://www.ecklers.com/product.asp?p...dept%5Fid=1427 Hope atleast a late answer is better than none at all
Old Sep 11, 2008 | 11:00 PM
...Roger...'s Avatar
...Roger...
The glass is different but you probably already knew that.
Old Sep 11, 2008 | 11:07 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I did not know that the glass is different. Do you know what is different about the glass? I thought I was good to go with them being interchangable.
David
Old Sep 11, 2008 | 11:11 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Okay thank you. The panels are the same and that is a good thing. DW says the glass is different and I need to learn a little more about that one to see if I will be changing some glass around. I have my 1977 AIM but not a 1974 AIM (I have one on order now) to compare, but not sure how interchangable they will be...
Thanks again.
David
Old Sep 11, 2008 | 11:18 PM
...Roger...
David
I think its diff at the back of the door.You also have some diff. in the guides in the door jamb.
Old Sep 11, 2008 | 11:24 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Okay thank you sir. I was hopeful but now I am doubtful.
It was worth asking the question and thanks for the help.
David
Old Sep 11, 2008 | 11:30 PM
...Roger...
These guys have to go in there plus some more.I think maybe the door is reinforced inside to hold the guides but not totally sure.
http://www.ecklers.com/product.asp?p...4&dept_id=1450
Old Sep 11, 2008 | 11:32 PM
TimAT's Avatar
TimAT
I have a 74 project and a set of 78 doors. The interior latch and the handle are way different. The lock assembly will bolt right in, but the rods that operate it are not the same.
Old Sep 11, 2008 | 11:34 PM
...Roger...
Check this thread it has some info.
http://forums.corvetteforum.com/show...ght=doors+vert
Old Sep 11, 2008 | 11:45 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Okay, thank you Roger. Great information in those posts and I understand what I would be up against, so the answer to a swap out is no thank you.
I'll tackle my issue another way and certainly appreciate your help sorting this one out.
Cheers.
David
Old Sep 11, 2008 | 11:46 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Thank you sir. I am very quickly determining I am not going to try this swap out.
Thanks for your help.
David
To Not Too Technical - But Who Knows?
