R4 Replacement with Sanden
Old Sep 14, 2008 | 05:54 PM
68/70Vette's Avatar
68/70Vette
Default R4 Replacement with Sanden
Where can I get the adapters to change out a R4 with a Sanden AC compressor. Any recommendations as to which Sanden I should buy?
I plan to use the Sanden with my stock factory 1970 AC. (The Serpentine kit I have for my 70 BB, is designed to mount a R4. I think a Sanden would be a better choice - weight, performance.)
Old Sep 14, 2008 | 07:05 PM
Paul L's Avatar
Paul L
Supplementary on that. What Sanden R-134 et al (hoses and the like) to replace a 1974 A6? No serpentine, just stock.
Old Sep 14, 2008 | 07:27 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I took my Sanden bracket from Classic Auto Air, along with a parallel flow condenser and all the needed hoses and adapters.
Old Sep 14, 2008 | 08:11 PM
Paul L's Avatar
Paul L
What would be the cost - parts only - to replace the A6 setup and convert to R134? Does someone have a turn-key conversion? I know of the various Vintage/Hot Rod/etc. complete retro kits but I am speaking of just the stock GM re-fit.
Old Sep 15, 2008 | 03:16 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Well, to be honest, its costly. I paid around $120 for the brackets, and $300 for the condenser kit (which contains the condenser, hoses, and the dryer) and another $180 or so for the compressor. Its a little costly, but my car is a daily driver, and I wanted something more reliable and easy to the engine than the stock A/C setup.
Old Sep 15, 2008 | 06:45 AM
noonie's Avatar
noonie
Sanden and others make units with various pulley/port configurations for serpentine and v belt.
Although the 5 and 7 numbering system is outdated, I would use the larger displacement 7 series comparable compressor even though it too is not as large a displacement as the original a6.
Sandens have issues too. You may investigate Nippondenso as well.
To R4 Replacement with Sanden
