engine
Old Sep 19, 2008 | 10:09 AM
timd02's Avatar
timd02
Default engine
What is the difference between the L48 and the L82 engines? I know that the 82 produces more HP but what is the difference internally? Is it easy to upgrade the 48 to produce more power without worrying about vacuum system?
Old Sep 19, 2008 | 10:33 AM
Durango_Boy's Avatar
Durango_Boy
The crank is forged in an L82, the pistons are flat tops, the compression is bumped up a bit as a result, the cam is a bit more aggressive, and I believe the valves are bigger in L82 heads. There are more subtle differences but the big difference is compression and cam.
Old Sep 19, 2008 | 10:39 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Easy to upgrade the L-48. AS long as the bottom end is still together, you could easily swap out heads and cam to get a good 50-60HP easily.
And of course, it all depends on how thick your wallet is.
Old Sep 19, 2008 | 12:23 PM
GTR1999's Avatar
GTR1999
The L82's are good street engines. They had the same bottom end as the LT1's: Pink rods, windage tray, 4 bolt mains,8" dampner,forged crank and pistons,202/160 heads with guides, aluminum covers,hyr cam vs the solid LT1 cam. Not sure if any had aluminum intakes like the LT1's. They didn't use Holleys either, Q-jet were used.
Old Sep 19, 2008 | 05:53 PM
timd02's Avatar
timd02
I know that the L48 only produced around 190 HP, how difficult would it be to get 300 HP out of the engine? I am thinking flat top pistons, mild cam, reworked heads and performance intake and headers. I don't want to have a "race" car but would like more power from the engine. I also know that it takes away from the value of the car but what about these crate engines. I would keep the original in storage in case I ever sold the car.
Old Sep 19, 2008 | 05:57 PM
Bruthish's Avatar
Bruthish
If you have the budget, and/or don't feel like building yourself, by all means get a crate and like you said, keep the original for any potential future buyer should you sell.
Old Sep 19, 2008 | 06:06 PM
Duke94's Avatar
Duke94
http://www.corvetteforum.net/c3/vette73/compair.htm
Old Sep 19, 2008 | 10:10 PM
jonfor's Avatar
jonfor
vortec heads with roller cam, headers with decent pipes, and no egr valve?
Old Sep 19, 2008 | 11:58 PM
Tom73's Avatar
Tom73
Here are the stats for the '73 engines, first year for the L82, and the highest HP (along with '74)for the L82s.
To engine
