Battery Question
Old Sep 19, 2008 | 12:18 PM
marines's Avatar
marines
Default Battery Question
In my haste to remove my old battery I neglected to determine which connection is the positive and which is the negative pole. Is the pole nearest the driver's side door the positive pole? Thanks for all your help.
Old Sep 19, 2008 | 12:28 PM
corvetteload's Avatar
corvetteload
look under car and see where the negative cable grounds to frame, should be directly under the battery compartment. Without having a Vette handy, I would say outboard is negative. Positive is inner and in line with the tunnel, at least on a 75 it is. Just check the frame for the negative cable end...................B
Old Sep 19, 2008 | 05:36 PM
Fonz69's Avatar
Fonz69
Old Sep 30, 2008 | 05:35 PM
kansas123's Avatar
kansas123
On my '72, the positive is closest to the door.
Old Sep 30, 2008 | 05:46 PM
75 Red Vert's Avatar
75 Red Vert
To Battery Question
