HELP! Sunvisor Question
Old Oct 1, 2008 | 07:46 PM
Silvette00's Avatar
Silvette00
Default HELP! Sunvisor Question
I've got new sunvisors and new sunvisor rods for my Pace Car, but the rod is loose when I slide it in the visor, letting the visor spin around.
Anybody had this problem, and more importantly, how do you fix it?
Old Oct 1, 2008 | 08:25 PM
Durango_Boy's Avatar
Durango_Boy
I think there are metal crush sleeves in that visor. You can close them a bit with a bench vise. Just do it in small amounts so you can get that visor on without crushing them too much. Can't undo it if you go too far.
Old Oct 1, 2008 | 08:53 PM
DC3's Avatar
DC3
I just fixed the opposite problem with my '73. Mine were too tight. When I finally got the rods out, it felt like there were two tubes for each rod, a long one the rod first is inserted into, a small gap and then a short tube about 1.5" or so. The two tubes were offset and putting the rod in a bind. I moved the short tube with my hands to be more inline with the long tube, lubed the tubes with silicone lube and mine now work fine.
DB suggested they were a crush sleeve. Might be but I was able to loosen mine by moving the two tubes more inline. You might be able to tighten yours by offsetting the short tube more - that is assuming yours are like mine. If you go the crush-it route, do like DB says and don't go too far.
DC
To HELP! Sunvisor Question
