Replacement Engine
Old Oct 5, 2008 | 05:59 PM
GunMan57's Avatar
GunMan57
Cruising
Default Replacement Engine
I have a '79 Corvette and was considering replacing my current 350ci engine with a 350 HO Crate engine (330HP, $2900.00). My current 350 is stock and is burning oil, which is evident by the blue smoke coming from my exhaust pipes. I intend to eventually repair the stock engine and put it in another vehicle. Is the Crate engine a good idea (for the price) or is there a better solution? Thanks.
Old Oct 5, 2008 | 07:40 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Is your stock engine a L-48 or L-82. I rebuilt my L-82 to 400+ RWHP and happy I went that way. Crates are ok, but I wanted to keep the L-82, since I rebuilt it myself, the cost was about the same. If you go to a crate, I'd recommend a 383ci.
Old Oct 5, 2008 | 08:02 PM
GunMan57's Avatar
GunMan57
Cruising
It is a L-48. I think it is rated at 195HP.
Old Oct 5, 2008 | 08:40 PM
thegazman's Avatar
thegazman
Default thegazman
How many miles on your engine. The smoke is probably coming from worn valve guides. If your engine is low mileage, you can change the heads, cam, and intake and pick up a lot of HP for a lot less money.
Old Oct 5, 2008 | 09:29 PM
TimAT's Avatar
TimAT
Blue smoke from the exhaust all the time is a sure sign the rings are going/gone. Pull that engine, wrap it up and stick it in the corner for a future rebuild if it's a number match. Get a crate 383 and drop in there and have fun. Or go with a 350. That will keep you driving and you can rebuild the stock engine at your leisure,
Old Oct 5, 2008 | 10:36 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I put a GMPP 330HP 350 in mine last winter. I've put about 1500 miles on it this summer. I've been very happy with it. It's definately got more punch than the old L-48. I like the idea of having a brand new engine too. Go for it.
Old Oct 6, 2008 | 07:00 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Jeffrey, that is one very nice looking engine in there. I like the looks of the 350HO myself. Did you get the turn key or did you get the base engine? I was told if I got the HO turn key I might have clearance issues with the surpentine belt. Yours looks like it fits just fine. Thanks for sharing.
David
Old Oct 6, 2008 | 07:32 AM
Jeffery73's Avatar
Jeffery73
It is the base engine. I had to use a different flywheel/flexplate and I bought an Edelbrock Performer Endurashine intake. I was able to use all of the other parts from my L-48. I had just rebuilt the carb and distributor so I wanted to be able to use them.
Shop around a bit. I found Jegs.com had the best price. They have it right now for $2659.99.
To Replacement Engine
