frame work
Old Oct 11, 2008 | 02:36 PM
charlieA's Avatar
charlieA
2nd Gear
Default frame work
Seems to be a lot of knowledgable people on this site, so I'm hoping some one can help me out. I'm trying my first frame off restoration on a 1976 vette. I have all 4 body mounts off each side and the three bolts (each side)holding the front bumper to the frame. However the front end will not seperate from the frame. WHAT AM I MISSING?
Old Oct 11, 2008 | 03:20 PM
chris75stingray's Avatar
chris75stingray
did you unbolt the core support?
Old Oct 11, 2008 | 03:46 PM
wills670's Avatar
wills670
Did you remove the rag joint from the steering box?
Or make sure you check the radiator support as the previous post said.
Old Oct 11, 2008 | 03:49 PM
charlieA's Avatar
charlieA
2nd Gear
I did unbolt the steering, but thought that the rad support would stay with the body. I'll try removing it.
Old Oct 11, 2008 | 04:18 PM
onaqwst's Avatar
onaqwst
dont forget to disconnect your ground wire from the frame.....and check to make sure theres no tail light wires wrapped around the frame
Old Oct 11, 2008 | 09:06 PM
72LS1Vette's Avatar
72LS1Vette
The radiator support shouldn't keep the front end from lifting. When you lift the body it will come up at the rear first and hang nose-down as it is lifted. Perhaps you just need to lift it more to see if the nose lifts from the frame. As someone else mentioned, make sure all of the ground straps are disconnected. You'd be suprised at how much weight one of those straps can lift without breaking.
Rick B.
Old Oct 12, 2008 | 09:14 AM
hwcoop's Avatar
hwcoop
See end of post for Body off checklist
http://forums.corvetteforum.com/show...+checklist+off
Old Oct 12, 2008 | 09:36 AM
cgc's Avatar
cgc
Does the front frame extensions go through the inner fenders like a 68 if so you will need to remove them.
charlie
To frame work
