77 Corvette Speaker Question
Old Oct 12, 2008 | 12:44 PM
MosportGreen66's Avatar
MosportGreen66
Default 77 Corvette Speaker Question
Question:
What is involved in changing the driver side speaker that is in the dash on a 77? The one that faces closest to the windshield / dash pad.
Thanks,
Dave
Old Oct 12, 2008 | 01:23 PM
...Roger...'s Avatar
...Roger...
I would lower the column down and lower the speedo-tach cluster and replace the speaker.I would also remove ALL the dash screws from door to door(except the 2 inside pass door jamb)to give plenty of flexibility.(zip,zip,zip and 2 min later they are all out)
Some will remove the top dash.....that can open a real can of worms.
Old Oct 12, 2008 | 02:05 PM
Paul L's Avatar
Paul L
Not for the faint-hearted....
Old Oct 12, 2008 | 02:36 PM
MosportGreen66
Wow. Much more involved than I thought. Unlike those Solid Axle cars where you remove the radio and 2 minutes later you have the speaker out.
Thanks very much. If I decide to do it I won't hesitate to contact either one of your guys for help.
-Dave
Old Oct 12, 2008 | 03:13 PM
Paul L's Avatar
Paul L
If you crack the upper dsah you have made a $300 mistake. But it can be done without incident with a little care and modest heat from a hair dryer to allow a little flex on removal. Don't you love that old 10-ohm speaker in the pic?
Old Oct 12, 2008 | 11:16 PM
MosportGreen66
We'll see what happens.
To 77 Corvette Speaker Question
