Ge 4537
Old Oct 24, 2008 | 08:45 PM
rayluka's Avatar
rayluka
Default Ge 4537
UPS just left. Brought me my new lights. Will post some pictures if I can complete the install tonight.
Old Oct 24, 2008 | 09:08 PM
...Roger...'s Avatar
...Roger...
Careful not to break off any screws.The 2 going up holding the bezel can be a pain.
Old Oct 25, 2008 | 09:14 AM
gatorbcn's Avatar
gatorbcn
Old Oct 25, 2008 | 05:09 PM
rayluka's Avatar
rayluka
Default Kinda Bubba
Well Ive bonded the connection to the light. Now to bridge a solder connection to the screws and it should plug right in
Comments?? Suggestions? And yes...its JB weld
Old Oct 25, 2008 | 09:34 PM
Scott Marzahl's Avatar
Scott Marzahl
That way should work too, you should also be able to just unsolder the screw on tabs and solder the spade connectors on.
Old Oct 25, 2008 | 09:56 PM
Skip Burney's Avatar
Skip Burney
Thats the same landing light as I have on my Piper PA-12 and it is waaaayyyy bright.
Old Oct 25, 2008 | 10:09 PM
colin75's Avatar
colin75
ive been interested in these for awile. i just dont understand how to properly connect a two connector bulb into my three connector plug. is that third leg not needed with these bulbs? colin75
Old Oct 25, 2008 | 10:11 PM
'75's Avatar
'75
Your high beam only has 2 connections. The hi/low has 3.
Old Oct 25, 2008 | 10:32 PM
rayluka's Avatar
rayluka
I just couldn't do it. I took it back to normal. I spliced the correct loop type connector . Dropped one bulb. So I will complete the left. Gotta buy a new rotory file to create clearance for the connector in the back of the mount.
Scott. It appears you are correct. Now that one is dead I'll see if I have skills soldering.
Old Oct 26, 2008 | 11:42 AM
Ironcross's Avatar
Ironcross
exactly the way I install mine. uses the OE headlite socket with out intermediary connectors. I also cut a notch in the headlight bucket to make the light attach in a certain direction with the 1/2 round filaments to the outside. Then just put it back together... and instant daylight......
Old Oct 27, 2008 | 09:10 PM
rayluka's Avatar
rayluka
Well its done on the left. Im waiting for my eyesight to return. Dont look into the light DUH......I was unable to orient mine as you directed Ironcross, due to the way it orients into the bucket. It has a notch on mine and on the bulb to match and it makes it align so the inside element is vertical. But as you said instant daylight
I think I just may stay with one regular bright and one "blinder" for now. There only 10 bucks a pop but 10 to ship. So it would end up costing 50 total because of my carelessness. I'll wait a week and see if I want another. BTW nice 62
Old Oct 27, 2008 | 09:50 PM
...Roger...
Are installing them on both high beam and low?
Old Oct 27, 2008 | 11:04 PM
Ironcross's Avatar
Ironcross
I cut a notch in the headlight bucket to match the position I wanted the filament to be in. I used a hack sat to make the 2 cuts and a pair of pliers to bend it in so it appears to be like the 3 original notches used to line the OE bulb but placed to position the 4537 how I wanted.
You should also be prepared to answer some unique questions as hardly no one knows what they are. I watch and smile at the comments. It`s fun too...
Bright, huh...
i told you so....wait until you get the other one in.
Old Oct 27, 2008 | 11:11 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
so lets see some night pics showing the difference.....
Old Oct 27, 2008 | 11:14 PM
ngroat7007's Avatar
ngroat7007
Ive been waiting for this all week... since i started seeing the landing light threads
Old Oct 27, 2008 | 11:38 PM
Ironcross's Avatar
Ironcross
There are no nite pictures available...
Old Oct 28, 2008 | 09:10 AM
rayluka's Avatar
rayluka
I'll get some tonight. My camera battery is dead. You wont believe the amount of light they put out
To Ge 4537
Old Oct 28, 2008 | 10:36 AM
Ironcross's Avatar
Ironcross
No nite pictures because it becomes day lite when you turn them on!
Old Oct 28, 2008 | 02:20 PM
rayluka's Avatar
rayluka
Just on high. You coulds never drive with those as a standard light. Also on the regular lights you have 3 wires. The regular lights actually get brighter when you turn on the brights
Old Oct 28, 2008 | 03:31 PM
...Roger...
Thats what I was thinking you were just doing the high beams but with some of the posts talking about 3 wires I wasnt sure.
