What causes this...? help! (pic)
Old Nov 2, 2008 | 01:11 PM
MN-Brent's Avatar
MN-Brent
Hows the gap at the back of the passenger door to the body?
Is it scraping any paint?
Might just be a hinge adjustment, possibly due to a previous repair where the door wasnt aligned so well.
B.
Old Nov 2, 2008 | 11:16 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
You can reduce that gap.
Try adding two 1/8" shims under the radiator support; one for each side. Carefully raise the radiator support and only lift enough to slide in the body shim.
You can also raise the front of the door. You'll have to loosen all eight hinge bolts behind the kick panel.
Good lucK!
Old Nov 2, 2008 | 11:27 PM
72and86's Avatar
72and86
B.
back gap on door is at least even. Alittle wider than I like but not horrible like this front...
Old Nov 2, 2008 | 11:28 PM
72and86's Avatar
72and86
Good lucK!
thanks. I think I see several don there already. see if I can get a pic, but its real dark down there.
Old Nov 3, 2008 | 12:00 AM
72and86's Avatar
72and86
more on the pass. door:
pass. door top:
pass. door side seams/gaps:
pass. gap close-up
drivers door
Inside drivers door:
Front:
Old Nov 3, 2008 | 02:39 AM
thegavel's Avatar
thegavel
Yup,
I got the same thing on my '74.
After going insane trying to get the door gaps right
(I've got the Lambo doors) I managed to get the
rear gaps OK, but the front looks like those in the
pics, I'm hoping it's the body mounts (They need replacing anyway).
So i'm looking forward to what THE EXPERTS here
have to say.
GAV
Old Nov 3, 2008 | 08:15 PM
Jim_Harrison's Avatar
Jim_Harrison
My 72 has the same issue, always thought it might have been hit, but think now it might have disbonded on the passenger side. Maybe we had the 2nd shift assembly guy.
