Big block pulleys and brackets
Old Nov 4, 2008 | 02:23 PM
Corey_68's Avatar
Corey_68
Originally Posted by CA-Legal-Vette
This might actually be the least expensive way to go. Do you have a kit number that fits or did you have to do it piece by piece?
I do not have the part number (it's been a couple years) but call March they have a Kit part # SPECIFICALLY Big Block C3's.
Old Nov 4, 2008 | 04:18 PM
Ironcross's Avatar
Ironcross
Then go to 70`s Chevelles with a BB.
should be available from a dealer
Old Nov 4, 2008 | 04:23 PM
Corey_68's Avatar
Corey_68
excellent BB resource.
Old Nov 4, 2008 | 10:05 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Hate to harp, but again, 70's Chevy's will have the long water pump set-up for most models if not all, except the Vette. I'm guessing there's not enough room between the radiator and fan in the Vette for the long pump, and Vettes continued with the short pump. Obviously this would limit interchangability between Vettes and other post-1969 Chevy's.
FWIW.
Old Nov 4, 2008 | 11:49 PM
eastltd's Avatar
eastltd
The Camaros use the same BB pump as a Corvette and the alternator is mounted on the left with or without air conditioning. And they all use the same alternaror mounting bracket too.
.....with air conditioning..
......without air coditioning...
...The Vette..
All 3 Photos are OE in every respect. No hot rod stuff, absolutely pure factory stock parts...
I'm thinking not all Camaro brackets are the same. Here's another OE version:
