Frame sanding pointers
Old Nov 8, 2008 | 05:39 PM
goatjacket's Avatar
goatjacket
Default Frame sanding pointers
Hi ya all,
Going to start cleaning and revamping the underside of my 72 body on restoration and my first project is Frame clean up. Any preferences on types of Sanders and what grit to use? For the individual components im hoping to just buy a sandblasting cabinet but for the large objects and frame i was unsure of a high speed or a DA sander and which would be best? How about grit on metal? I dont have any serious rust but want to get it nice and bare before shooting it with an epoxy paint. A 50 to 80 grit good enough? Sorry if these seem like really stupid questions, but i'm pretty new to metal sanding...especially on a car!
Any tips and advice is more than welcomed. Cant wait to get started!
Old Nov 8, 2008 | 09:40 PM
tfi racing's Avatar
tfi racing
Frame off or body still on?They are dangerous beasts,but if the rust is light a wire wheel cup on an angle grinder does a nice job.Just make sure you are suited up and all your PPE is in place...
Old Nov 8, 2008 | 09:51 PM
goatjacket's Avatar
goatjacket
yes body still on but the underside is pretty bare, no spring, gas tank, exhaust. So an angle grinder or any kind of air sander and a wire wheel will work? Not much rust at all but I want to be thorough and remove what I can for pieces not being replaced.
Old Nov 8, 2008 | 10:52 PM
Fonz69's Avatar
Fonz69
A grinder and a wire cup is what I used and a speed blaster for the hard to reach areas
I found that the wire cup with the wires that were twisted into larger sections worked the best on the electric grinder.
The speed blaster if you do not know what it is, holds a few cups of blast media in kind of a spray gun type application that uses a trigger to activate it.
P.S. wear saftey gear when using that wire cup, I used a face shield and welding gloves, it did not stop the occasional loose wire from flying off the cup and sticking into my leg though!
Old Nov 9, 2008 | 07:48 AM
goatjacket's Avatar
goatjacket
well I agree the popular vote is for an angle grinder and a wire wheel. I think this will be my next purchase. As for the speed blaster; can you find those at the main hardware stores? I've never heard of this tool but it sounds like the perfect medium, especially on those tight areas up front. thanks for all the feedback
Old Nov 9, 2008 | 08:31 AM
Fonz69's Avatar
Fonz69
You should be able to get it from any good speed shop in your area, I bought mine thru Carquest
http://www.zendextool.com/speedblaster/
Old Nov 9, 2008 | 11:50 AM
rosslato's Avatar
rosslato
i did what your doing. i used a wire wheel to do most of the frame, for the removealbe parts i sandblasted. be sure to show pics when your done. tedious work but well worth it when your done.
more pics here
http://smg.photobucket.com/albums/v3...slato/?start=0
Old Nov 9, 2008 | 01:56 PM
goatjacket's Avatar
goatjacket
Rosslato: those are some beautiful shots and a fantastic undercarriage. Mine will be a subtle driver so I'm unsure whether I'll go to your detail, but that is great looking.
Question, after the sanding what did you use to coat the frame? An epoxy paint?
Old Nov 10, 2008 | 04:30 AM
hunt4cleanair's Avatar
hunt4cleanair
I've got a bead cabinet but wondering how to do the large stuff remotely
Old Nov 10, 2008 | 11:00 AM
rosslato's Avatar
rosslato
thanx. i used Por-15 system( http://www.por15.com/)on frame and all parts and then top coated. it's worked excellent for me. if u decide to go that route PM me for useful tips.
Old Nov 10, 2008 | 11:05 AM
rosslato's Avatar
rosslato
harbor freight has a sand blaster you use outside for under $100 that works very well for the larger parts, thats what i used.
Old Nov 10, 2008 | 03:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Before you get too far along, you will find factory grease pencil markings on the frame, along with the A. O. Smith factory stencil, all of which you may want to keep. If you don't want to keep/replicate the factory markings, taking a bunch of pix for record wouldn't hurt.
Old Nov 10, 2008 | 04:14 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I will be doing this as well to my '73 when it comes back from the paint shop.
I bought some paint stripper wheels, that I hope will be good to use with my small drill for the areas close to the brake and fuel lines.
In the past when stripping a frame, I have used the wire wheels and wire cups like others have suggested. Be careful, they will rip right through you if you are not well protected. Only use a drill that you can control, and one that is variable speed. The cheap ones from Harbor Freight work well because they are light and mostly plastic.
I have never used a sand blaster. I have one, but the lift is in the shop, and I don't want to use the blaster indoors. I may have to roll the car outside to do the sandblasting.
When it is bare, I plant to touch up the factory welds a bit. They look to be rather poor.
Be sure to post some progress pictures when you get started.
Old Nov 13, 2008 | 03:59 AM
hunt4cleanair
Almost forgot to add but I started using a product I picked up from one of our regular contributors called Rust Cure. Spray it on and it neutralizes the rust, providing a surface that can be painted. I scrapped the rust off and than spray on the product...its a rust converter type product.
Old Nov 13, 2008 | 09:32 AM
1nicecorvette's Avatar
1nicecorvette
more pics here
holy detail!
To Frame sanding pointers
