Heater core question
Old Nov 9, 2008 | 09:57 AM
nutsy's Avatar
nutsy
Default Heater core question
Ive been reading about lots of ruined rugs from heater core leaking. i have a shut off valve on 1 of my heater hoses which i keep closed. does this prevent me from having a problem with a leaking heater core LEAKING ON RUG? i dont use heater, only AC. THANKS.
Old Nov 9, 2008 | 09:59 AM
Durango_Boy's Avatar
Durango_Boy
So long as the shutoff valve is on the pressure side then yes it will keep fluid from circulating. To be safe though you can install a shutoff valve on the other line, and drain the fluid out during the times that the heater is not used. Even more insurance.
Old Nov 9, 2008 | 10:11 AM
nutsy's Avatar
nutsy
Originally Posted by durango_boy
so long as the shutoff valve is on the pressure side then yes it will keep fluid from circulating. To be safe though you can install a shutoff valve on the other line, and drain the fluid out during the times that the heater is not used. Even more insurance.
thanks durango boy. Will do.
Old Nov 9, 2008 | 10:53 AM
hammadown's Avatar
hammadown
I have 2 shutoff's on mine.................
Hammadown
Old Nov 9, 2008 | 07:43 PM
nutsy's Avatar
nutsy
thats what im gonna do HAMMADOWN LIKE durango said. what side is pressure side? mine is on the one coming from top of block, not water pump.
Old Nov 9, 2008 | 11:19 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'd bypass the heater core altogether since you never run the heater.
Also, the entire coolig system is under pressure so closing off one of the two hoses won't prevent a leak.
FWIW.
Old Nov 10, 2008 | 07:23 AM
nutsy's Avatar
nutsy
CAN YOU TELL ME HOW TO BYPASS ALTOGETHER? thanks. also if you block off both there wont be pressure will there? AND WHEN YOU DO THIS SHOULD YOU DRAIN HEATER SIDES OF HOSES?
Old Nov 10, 2008 | 08:03 AM
Durango_Boy
Bypassing completely is not too hard but you'll either need to replace the water pump with one that doesn't have the heater hose nipple or remove the nipple and plug the hole. The other aspect is the intake manifold nipple, which you can remove and replace with a plug. Then just remove the rubber hoses from the heater core, and plug them so nothing gets in.
Old Nov 10, 2008 | 05:30 PM
nutsy's Avatar
nutsy
THANKS, DURANGO, seems like the easiest way is the way you suggested by putting 2 valves, this way it looks like its supposed to also. thats what ill do. when i cut the hose should i drain fluid from hoses that go to firewall side?
To Heater core question
