Rear suspension help
Old Nov 15, 2008 | 10:58 PM
Grumpy 427's Avatar
Grumpy 427
Default Rear suspension help
Hey Guys, its been a long day. One broken leaf spring bolt in the rear end housing, and the front trailing arm bolts are in a bad way.
The broken bolt i assume will need to be drilled out and have a helicoil put in.
Is a saws-all and torch the only way to get the front bolts out?Either that or i will cut the hell out of them and buy new? I am out of practice on working on old cars. Is it cheaper to rebuild the old? or buy a new assembly?
Old Nov 15, 2008 | 11:18 PM
TimAT's Avatar
TimAT
The front T/A bolts can be a beeotch. Most of the time a Sawzall and some good blades are the only way to get them out. Torch is going to destroy something you want to keep (like the car?) Cut thru the shims and the bolt and they come out. The bolts rust into the center of the bushings. Put some new bushings in (takes a flare tool and a press), then get the Stainless bolts and shims from Van Steel or VB&P.
The broken bolt in the housing will need to be drilled out. If it's a rear most bolt you might be able to soak it with some good penetrating oil and get it out. If it's a forward bolt, watch out how deep you drill. Those holes go right into the differential. Too deep and it'll leak. It'll all depend on how lucky you are.
Old Nov 16, 2008 | 12:49 AM
Grumpy 427's Avatar
Grumpy 427
Thank you for the advice. Any idea how the Rear hubs come apart?
Old Nov 16, 2008 | 01:30 AM
stinger12's Avatar
stinger12
With a press or a spindle knocker. The bearings are pressed onto the spindle - both inner and outer. After you remove the spindle flange, you will see an oil seal. Underneath that oil seal is the inner bearing. That inner bearing is preventing the spindle from pulling out of the assembly. You either have to press the spindle off of that bearing, or use a spindle knocker and smack the spindle free from that inner bearing until it pops loose. You use a bearing splitter to remove the outer bearing once the spindle is out.
Old Nov 16, 2008 | 06:21 AM
RunningMan373's Avatar
RunningMan373
If you broke the bolt there should be no torque holding it in. If there's no torque holding it in, it should turn relatively easily. If you cut a nice fat slot in the remaining stud, with a dremmel or like, you might be able to turn it out by hand. If it's broken below the lip, you can drill and pound in a slightly larger junk phillips and turn. with no torque, it should turn relatively easily. Not to rub it in,, but when i replaced my spring i used new grade 8's.. the torque on these is 70ft/lbs I didn't like torquing them last week. no like.
Unless you broke it while removing it,, in which case, I would just buy a new cover, they're cheap.
Old Nov 16, 2008 | 10:00 AM
Grumpy 427's Avatar
Grumpy 427
Yes the bolt broke from removing it. So i guess i will start looking for a new cover. Thank you for the replies everyone, these cars are a bit complicated on the back end to work on. Thank Goodness its winter, i have 6 months to work on it lolol.
Old Nov 16, 2008 | 10:27 AM
eastltd's Avatar
eastltd
That brings back memories! The rear end cover was the first part I ordered in the frame off restoration.
Good luck with the repairs
Old Nov 16, 2008 | 10:43 AM
Wizziamrr's Avatar
Wizziamrr
I also removed the trailing arms off my "80", spend a little money and get good "long" sawsall blades. I found a little shop in PA. called Bears. they rebuild TA's. Excanged my old rusted trailing arms and got rebuilt ones. Powder coated completely rebuilt and simply re installed them in my car. If you want more info on Bears I get it for you.
Old Nov 16, 2008 | 01:49 PM
numbrsmtch's Avatar
numbrsmtch
i find it helpful to spray all parts to be worked on with PB Blaster a week prior to and every night until i get to it. It really helps loosen things up. It doesnt prevent breakage but it makes life a bit easier.
Old Nov 16, 2008 | 03:48 PM
Grumpy 427's Avatar
Grumpy 427
Yes we sprayed the heck out of everything lol. Most of it came apart real well, just the rust in the hard to get areas. I will go buy or rent a saws all and try to find some 8" long hack saw blades. see what i come up with. After several hours of lube and prying, i was able to get the bolts to turn and the shims loose.
Old Nov 16, 2008 | 08:33 PM
69small block's Avatar
69small block
Default rear sus
do you have access to a drill press you can set the rear end cover on one and carefully drill out most of the bolt ck your depth on another hole so you dont go to deep I also use the stuff called aerokroil penetrant ck it out on line it some great stuff I am doing the rear suspension on my 69 now too and have been able to get all the bolts out no problem impact gun help that too Im also doing the diff carries bushing too I ahve parts every were besure to be paitent and of course gary is my mentor he always give you the right way to do it
Old Nov 16, 2008 | 09:17 PM
Grumpy 427's Avatar
Grumpy 427
Yes this is not a problem, i have access to a couple of friends with machine shops, so the bolt removal will not be a problem. The T/A removal will be some fun though.
Old Nov 16, 2008 | 09:48 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I sprayed my TA bolts with PB blaster for a few days and then used an air hammer. One side popped right out. The other side I had to hammer at for 20 minutes or so but it eventually came out. Give it a try if you have one.
Good Luck.
Old Nov 17, 2008 | 02:01 PM
Grumpy 427's Avatar
Grumpy 427
Hey Bill i called today and as soon as i get them cut of, i will send then down for rebuilding. This will be the best way to do this. The will do the lower link bars as well.
Thanks again for all the input on this thread, this is how we get things done on this site. I appreciate all the help.
Sheldon
Old Nov 22, 2008 | 11:11 PM
Grumpy 427's Avatar
Grumpy 427
Well lesson learned.I bought a sawsall and the long blades. HUGE TIP. get every thing loose enough to get the shims out, once they are out the bolts are easy to cut. 15 min a side after the shims are out.Now to ship them off for rebuilding.
Thanks for all the help guys..
Old Nov 22, 2008 | 11:29 PM
TimAT's Avatar
TimAT
Good show! I did my T/A's last winter. Took the nuts off, used a long brass drift and tapped them out. But then again, I've been around my vette since 1971 (just bought it the end of '06) and I KNOW it hasn't been in the rain or snow since 1974. Before that, if it was raining it went, and stayed home all winter except for 1973. No rust anywhere on anything.
Old Nov 23, 2008 | 02:47 AM
Grumpy 427's Avatar
Grumpy 427
As soon as i get the drive shaft off the car i can drop the rear end.then the gas tank comes out and the cleaning can begin. OH YEAH. lolololol
To Rear suspension help
