passenger headlight help
Old Nov 16, 2008 | 04:48 PM
7dSHARK's Avatar
7dSHARK
Default passenger headlight help
help wanted..i have a 70 vette. changed the vacuum hoses quite a while back so they are fine. last night the passenger side light would only come up a half an inch unless i helped it . went down just fine when i turned lights off. the drivers light works fine. i ASSUME the problem is with the passenger side light or between the passenger side light and the driver side light. i can't find my headlight troubleshooting book. can someone give me a methodical way to diagnose this problem before i just start replacing parts. limited experience so you can't be too basic. thanks for the help..matt
Old Nov 16, 2008 | 05:09 PM
'75's Avatar
'75
You will need a hand held vacuum pump to make it easy. With the engine off, disconnect the hose from the rod end of the right actuator and apply vacuum with your pump or even your mouth to see if it raises the light assembly or just leaks the vacuum out. If it leaks out it is probably the rod seal. It could also be a problem with the relay valve. Perhaps someone will chime in with a troubleshooting diagrahm.
Old Nov 16, 2008 | 09:31 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I got some "T" connectors and some tubing and tried running both lights from a single vacuum relay. This help isolate the problem, and work so well I kept it that way. One less piece of rubber tubing running to the front of the car!
Old Nov 16, 2008 | 11:30 PM
7dSHARK's Avatar
7dSHARK
i'm going to look at it again in the daylight..will i be able to see which is the rod end? will i need to take off my hood? thanks
Old Nov 16, 2008 | 11:36 PM
7dSHARK's Avatar
7dSHARK
would you please explain in further detail or furnish a diagram. sounds good but i can't picture what your'e talking about. will probably do it even if it is not part of my current problem...thanks
Old Nov 17, 2008 | 08:30 AM
...Roger...'s Avatar
...Roger...
Here is how Raphiki is hooking his up.
Old Nov 17, 2008 | 10:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the vacuum relay. The relays send vacuum to the headlight actuators.
To passenger headlight help
