Blower Motor Wiring
Old Nov 17, 2008 | 05:41 PM
Emeightch's Avatar
Emeightch
Default Blower Motor Wiring
I posted this a while back, but the responses just didn't seem right. Looks like the purple wire with the female boot goes to the corresponding male boot on the lower rh side. Also, do I have the black ground wire routed right and does it matter how the motor itself is indexed? Ugh, anyone have a pic of thiers?
Old Nov 17, 2008 | 05:44 PM
Durango_Boy's Avatar
Durango_Boy
I don't know about the proper indexing but I do know there is an air tube from the motor housing to the air box, and that can only go on one way so that would tell you how to index the casing.
Old Nov 19, 2008 | 06:56 PM
Emeightch's Avatar
Emeightch
Anyone? Just a few pics. Please.
Old Nov 19, 2008 | 08:35 PM
GPGG70's Avatar
GPGG70
I'll see if I have a pic. As far as the tube is concerned the heater blower motor does not have this tube but the AC blower motor does have one going to the evaperator housing to help keep the motor cool. Thats a quote from the ncrs judging manual.
Old Nov 19, 2008 | 11:47 PM
GPGG70's Avatar
GPGG70
Ok, here is the only picture I have worth looking at. Sorry but I have put the rebuild pictures somewhere else and cant find them. This is the picture when I took it out of my 70 coupe.
Hope this will help you. Cant tell you if your car has AC or not and if it does like DB said the tube will only allow you to hook up one way and the indexing wont matter.Take a look at the 2 holes at the bottom of the pictures. The hole on the left has what looks like a blackish square around it. If I remember right that is the spot where the ground tab went on this motor. The condensor was about 12 oclock and the tube is about 6 oclock and the ground tab is around 2 oclock. If all the hole for the motor housing plate line up with the heater box holes then I would say go with that.
Old Nov 20, 2008 | 10:29 AM
eastltd's Avatar
eastltd
I'm not sure if these shots will help much so I'll take a few with more detail tonight and post them for you.
Old Nov 20, 2008 | 10:53 AM
Durango_Boy
Hmm...that's a good pic, and it shows that there isn't a hose on a non A/C air box. Sorry, I never realized that air box didn't have the air hose.
To Blower Motor Wiring
