Seat restoration link?
Old Nov 25, 2008 | 10:25 PM
MakoShark72's Avatar
MakoShark72
Default Seat restoration link?
Gonna tackle my '72 seats over the holidays. I have new foam and leathers. Plan to disassemble and repaint then rebuild. Is there a step-by-step "how to" somewhere out there?? I have the install kit and plan to get a good set of hog ring pliers. I may have a local shop do the foam/cover install, as I think its a PITA...
Thanks...
Old Nov 25, 2008 | 10:40 PM
DMONSVETTE's Avatar
DMONSVETTE
DIY
http://www.corvettemagazine.com/2001...s/seatspg1.asp
Old Nov 26, 2008 | 01:22 AM
GPGG70's Avatar
GPGG70
Ecklers has a DVD on how to restore the seats for $25.00.
Old Nov 26, 2008 | 09:05 AM
thegazman's Avatar
thegazman
Default thegazman
I recovered the seats in my 79 last year. The warmer the leather, the better. I used a hair drier to heat the leather in areas where I needed to stretch it to pull into areas that were tight.
Old Nov 26, 2008 | 10:36 AM
MakoShark72
Originally Posted by DMONSVETTE
Makes it look pretty easy...Thanks! I'm going to give it a try.
Old Nov 26, 2008 | 11:10 AM
Mashman's Avatar
Mashman
Ugghhh! If I had all the skin and blood I've lost over the years after making similar statements.....
I hope you didn't jinx yourself, just take your time, and don't force yourself.
Good luck,
Matt
Old Nov 26, 2008 | 12:43 PM
TopGunn's Avatar
TopGunn
Worse damn job I ever did on ANY car! I'd rather change the engine that do that again!
Remove all sharp instruments withen reach from the room you're working in!
Old Nov 26, 2008 | 08:53 PM
MakoShark72
Now thats the reply I was expecting!! Still gonna try it, I'll let you know how it goes...
Old Nov 26, 2008 | 11:39 PM
seaboltm's Avatar
seaboltm
i did my seats this last summer. getting the metal frames right was fairly easy. I had to do a bit of MIG welding on the driver side frame. Putting the seat covers on is just ridiculous. My car is now a daily driver, so the seats are OK, but i would love to have a professional redo them someday, because the job i did is certainly not professional. I followed the link listed here, and it was handy. Still, tough job to do right, and there is ZERO room for error, which if this is your first job you are bound to make some errors.
Old Nov 27, 2008 | 11:01 AM
MakoShark72
Makin' me think twice....
"zero chance of error" exactly what do you mean? Rips/Tears?
Thanks!
Old Nov 27, 2008 | 12:41 PM
avner's Avatar
avner
Those are my 72 seats that I did this last summer, it will be easier to do it with two more hands.
Avner
Old Nov 27, 2008 | 01:33 PM
dbeall1968's Avatar
dbeall1968
I did mine last summer, first time doing anything like it. I was patient, and I sandblasted the frames, repainted them with a por-15 type stuff, then regular black enamel. I took the chrome parts and screws, polished them with a dremel, then painted them with rustoleum clear. The trick is to do one at a time so if you forget how it goes, you have one to look at. Mine came out great. I am now considering painting it myself, so I can say "I did it all" when asked about the restoration.
Old Nov 27, 2008 | 02:39 PM
GPGG70's Avatar
GPGG70
This might help you decide. Trying to show you a before and transition to the after on my seat rebuild. Take lots of pictures of the rebuild. It helps when you put it all back together.
I had fun rebuilding my seat.
Old Nov 27, 2008 | 07:34 PM
turbojet's Avatar
turbojet
Not that hard of a job just takes time. Something that has already been said and can't stress enough is lay the leather and foam in the sun on a really hot day. I put the bottom on a drop cloth on my patio stood on top of the frame(to squeeze all the air out of the foam) and tucked the leather onto the frame. Made it a lot easier. Good luck
Old Nov 27, 2008 | 10:10 PM
Paul L's Avatar
Paul L
GPGG70 has done a very nice summary! I can only add that you might consider these reinforcement plates on the bottom frames. They prevent cracking damage in a high-stress area. Willcox has them.
I did not have the gonads to do the job. I paid to have it done.
To Seat restoration link?
