Whats It Worth
will draw about 1000 more. in mint condition they go for about 10-13k.
start deducting work needed from there.
1977 Options:
Code
Description
Quantity
1YZ37
Base Corvette Sport Coupe
49,213
A31
Power Windows
44,341
B32
Color Keyed Floor Mats
36,763
C49
Rear Window Defroster
30,411
C60
Air Conditioning
45,249
D35
Sport Mirrors
20,206
FE7
Gymkhana Suspension
7,269
G95
Optional Rear Axle Ratio
972
K30
Speed Control
29,161
L82
350ci 210hp Engine
6,148
M21
4 Speed Manual Close Ratio
2,060
M40
Turbo Hydra-Matic Automatic Transmission
41,231
NA6
High Altitude Emissions Equipment
N37
Tilt-Telescopic Steering Column
46,487
QRZ
White Letter Steel Belted Tires GR70x15
46,227
U58
AM/FM Radio Stereo
18,483
U69
AM/FM Radio
4,700
UA1
Heavy Duty Battery
32,882
UM2
AM/FM Radio Stereo With 8 Track
24,603
V54
Luggage and Roof Panel Rack
YF5
California Emissions Test
YJ8
Aluminum Wheels
12,646
ZN1
Trailer Package
289
ZX2
Convenience Group
40,872
Serial Numbers: 1Z37L7S400001 through 1Z37L7S449213
DO NOT TRY TO START IT WITHOUT CHANGING THE FLUIDS, AND PRIMING THE MOTOR WITH OIL.
Chances are you will need to replace the fuel tank. It all depends on how much gas is in it. If it is full, it would be better than empty. There will be less rust.
The fuel is rotten and needs to be drained and the tank needs to be flushed. I would add a cheap clear plastic fuel filter by the carb, to catch the trash left in the lines.
You would need to rebuild the carb, replace the plugs, belts, and hoses, change the water, ps fluid, brake fluid, transmission fluid, and rear gear lube before trying to drive it. You may need to change the rotor button and distributor cap.
Check the ground wires, the starter wires, and the battery wires. Spin the alternator, water pump, and put a wrench on the crankshaft and manually turn the motor a few times with the plugs out before you try to start it.
