Fuel Sender
Old Nov 28, 2008 | 01:03 AM
law dog's Avatar
law dog
Default Fuel Sender
I`m experiencing an inaccurate reading on my fuel gauge. When it`s cold it reads fine. When the car warms up the fuel gauge will drop to 1/4 tank. I`m thinking it`s the fuel sender. Any suggestions?
Old Nov 28, 2008 | 01:22 PM
BenUK's Avatar
BenUK
The sender is so far from the engine that it can't be a heat problem at that end.
I think I'd check the gauge before the sender. It's easier to do this too.
Old Nov 29, 2008 | 11:49 AM
law dog's Avatar
law dog
Thanks....do you feel it might be a good idea to go ahead and replace the gauge? I went out and started the car yesterday to warm it up. The gauge read fine. But, if I take it for a drive, the gauge will eventually give an inaccurate reading. It bounces around for a short time then sits on 1/4.
Old Nov 29, 2008 | 12:10 PM
speedreed8's Avatar
speedreed8
http://forums.corvetteforum.com/c3-t...uld-share.html
i would test the gauge first. the above article is about that
Old Nov 29, 2008 | 12:18 PM
BenUK's Avatar
BenUK
Maybe the sender is sticking. It's basically just a float on the end of a long pivoted rod. You might be able to see it if you take off the gas cap and shine a flashlight into the tank, and if you can poke a piece of stiff wire in there then you might be able to judge whether it's at all stiff to operate.
But I still think I'd guess a malfunction with the gauge or the connections at the back of the gauge cluster maybe. New gauges are expensive though. You could try driving with a ohmmeter connected to the gauge feed wires to see whether the sender's reading is changing unrealistically or whether it's steady.
Old Nov 29, 2008 | 12:20 PM
BenUK's Avatar
BenUK
Ahh yes, this is good.
Old Nov 29, 2008 | 12:53 PM
law dog's Avatar
law dog
Excellent article.....i`m printing it for my records.
I will have to say, since buying my Corvette this forum has been very useful & friendly. Thanks to all.
To Fuel Sender
