81 wipers not working...help!!!
Checking fuses
There is a Windshield Wiper relay that may have failed
Check the wiring around the motor to see if somone may have disconnected for some reason such as due to a mechanical problem that they were having.
The motor itself may have failed as well.
You can check to see if you're getting power to it at all when **** is turned on.
This will get you going. In the Search function there is an article I cannot find about a relay between the seats that can also give you headaches.
Mine stops and starts again a week or so later. Probably a ground but I only get caught in rain once or so a year so it's kinda a "raining day" project I've been putting off for 15 years!
JU
