'75 Fuel Tank Bladder
Old Dec 4, 2008 | 07:34 AM
danbrennan's Avatar
danbrennan
Default '75 Fuel Tank Bladder
I just pulled the fuel tank out of my '75, to replace some leaky rubber lines, and noticed my tank has a rubber bladder. I was just curious, what was the purpose of the bladder? While I have the tank out, I'll sand the outside down and put a coat of paint on it - is there any preventative maintenance I should perform on the bladder, while I have the tank out? Thanks.
Old Dec 4, 2008 | 08:44 AM
Durango_Boy's Avatar
Durango_Boy
The bladder was a safety feature, designed to keep the fuel in the tank in the event of an accident where the tank itself ruptured.
There are a lot of problems these bladders can cause. They deteriorate and fall away from the walls, collapsing, causing a loss in fuel capacity. They can also keep the fuel float from giving you an accurate fuel level reading. Sometimes fuel or water gets behind them, and rust holes develop causing leaks.
Mine was shot when I pulled my tank. I didn't want to fuss with buying a new one so I cut the nut ring off of the top of the bladder and put the tank back in without it since it was in great shape. I actually gained about a full gallon of capacity.
If yours is in good shape and it's holding it's form then re-use it. If it's bad, you can either replace it or go without it.
Old Dec 4, 2008 | 09:12 AM
Jim Shea's Avatar
Jim Shea
I have never found any supplier that had the bladder available to purchase (not refering to eBay.) I had heard that no one wanted the liability associated with a bladder failure and potential fire.
I agree with all of the above bladder problems and old age. (Gee that might be talking about me personally.)
Jim
Old Dec 4, 2008 | 09:51 AM
...Roger...'s Avatar
...Roger...
Has anyone tried swapping in an earlier tank that has the sender and fuel coming out the bottom?
Old Dec 4, 2008 | 04:03 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
.....more "bladder info" here.....
http://forums.corvetteforum.com/c3-g...k-bladder.html
Old Dec 5, 2008 | 11:03 AM
danbrennan's Avatar
danbrennan
The rubber on mine looks to be in great shape, and its still pressed up against the walls, so I guess I'll just make sure the vent is clear, and put it back. '74 and earlier didn't have the bladder, though? Maybe it was in response to some crash fires.
To '75 Fuel Tank Bladder
