Snap On Digital Torque Wrench
Old Dec 5, 2008 | 08:44 AM
Maymyvetteliveforevr's Avatar
Default Snap On Digital Torque Wrench
Do they need to be calibrated or even set back to zero after use, which in this case would be 25 ft lbs since it won't go to zero? I know the click, dial etc do.
Old Dec 5, 2008 | 09:43 AM
Durango_Boy's Avatar
Durango_Boy
It should tell you that in the user's manual. A quick call to Snap on Tools tech or customer service should also get you a correct answer.
Old Dec 5, 2008 | 11:18 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
my assumption would be that it does not need to be re-zero'd after each use.
Old Dec 5, 2008 | 11:42 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
If it is anything like a standard torque wrench you need to run it back down to near the lower end of the scale. I would guess this has an electronic strain gauge of some sort in it, so it may not be required to return to zero every time.
I would expect that is a high dollar torque wrench. I would be sure to do whatever Snap-On recommends to keep it in good working order.
Old Dec 7, 2008 | 06:52 PM
Thanks for the reply everyone, I missplaced the instruction manual but I'm sure I can find one online somewhere and print it out. I was hoping someone that has the same Torque Wrench would have know the answer.
Old Dec 7, 2008 | 08:43 PM
BigBlockTank's Avatar
BigBlockTank
In the Air Force, we calibrated all measurement equipment bi-annually. Is that correct for every 2 years? So yes, it needs calibration.
Does it need to be zeroed after each use? Is it gonna hurt it if you do?
BBTank
Old Dec 7, 2008 | 08:51 PM
baxsom's Avatar
baxsom
i get my AF issued torque wrenches calibrated as well and never ever once has the torque wrench that gets used and abused for the last 6 years since it was new ever came up bad.
To Snap On Digital Torque Wrench
