left head light wont go down
Old Dec 14, 2008 | 12:43 AM
randommj's Avatar
randommj
Default left head light wont go down
what could cause this? Im not near the car but I will be in about a week. My dad called me the other day telling me that he moved the vette and that my left head light wont go down, help
Miles
Old Dec 14, 2008 | 08:56 AM
...Roger...'s Avatar
...Roger...
Vacuum leak
Bad left relay leaking or sticking
Dog leg mechanism needs cleaned and is sticking
Old Dec 14, 2008 | 10:22 AM
BassCat's Avatar
BassCat
Yep, probably bad relay or actuator. Crank it, pull the lights on, then lean down between the actuators up front and listen. Sometimes you can hear those relays leaking.
Old Dec 14, 2008 | 09:50 PM
randommj's Avatar
randommj
ok, Ill check for those when I get home, but would the bad relays or vacuum leak be something that could develop so quickly? wouldent it have been something that I could have noticed before? or is it one of those things that happens over night?
Miles
Old Dec 14, 2008 | 11:25 PM
68AIR's Avatar
68AIR
You probably have a hose off up front. Simply pop the hood and look on the christmas trees between the actuators.
Old Dec 15, 2008 | 07:18 AM
1nicecorvette's Avatar
1nicecorvette
Miles
well it has to start sometime so why not now? what i do is this, i run the engine and let it build vacuum for a bit. ill stop it with the headlights up and listen for an air leak, ill do the same thing with the lights down and listen up front as well as back but the check valve and filter.
also get up under the dash check the relaease valve directly below the steering wheel.
Usually one side being a problem is a component of that side
example (actuator, relay, or hose for that side.) youll find it!
Old Dec 15, 2008 | 09:08 AM
BassCat's Avatar
BassCat
Yep, they can go bad overnight. I recently had a relay up front just start leaking out of the blue. Once you locate the problem, it's an easy fix. Everything is pretty easy to get to. Except maybe the back of the headlight switch.
KC
Old Dec 15, 2008 | 11:59 AM
randommj's Avatar
randommj
awsome, Thanks guys! Ill get on it thursday!
Miles
Old Dec 16, 2008 | 02:25 PM
1nicecorvette
KC
now you jinxed him!
Old Dec 16, 2008 | 09:28 PM
BassCat's Avatar
BassCat
"Now you jinxed him". It's probably something simple and cheap to fix.
KC
Old Dec 16, 2008 | 09:35 PM
randommj's Avatar
randommj
KC
YEA!
Miles
Old Dec 17, 2008 | 06:50 AM
BassCat's Avatar
BassCat
Hey Miles, if any of those relays and actuators are the original ones, you might want to just replace them all. When I first started working on my lights, I replaced one leaky relay, and that fixed them for a short while. Then one of the actuators started leaking. Before it was over, I had replaced both actuators, both relays, vacuum check valve, and filter. That was over a year ago, and they're still working perfect. It's kinda like the brake calipers on these cars. If the car has sat up for a while, they're all eventually gonna leak. Good luck,
KC
Old May 14, 2009 | 05:45 PM
CCrane65's Avatar
CCrane65
Miles
Quickly? It's been there for 37 years. I'd say it took a while to go bad.
cc
Old May 14, 2009 | 05:47 PM
CCrane65's Avatar
CCrane65
Originally Posted by lausbub92003
if you still have problems with your headlights check out the electric conversion kit from www.ECPB.biz the kit comes complete with everything you need and installs in two hours
Dude, what's with you and your conversion kits for everything vacuum?
Ok, I've seen 4 posts concerning vacuum problems and you posted a link to conversion kits in each one. I get the distinct feeling you are selling these kits. You need to talk with the mods first.
cc
Old May 14, 2009 | 05:52 PM
Mike Ward's Avatar
Mike Ward
Slime bag non-supporting vendor?
To left head light wont go down
