well the cars engine is a CE engine. I also know that the stamp on the heads are say that th heads are from a 67 427 L36.
The stammp on the back of the block says 3999289 which according to this site http://www.nastyz28.com/bbcmenu.html
means it is a 72-78 2 bolt car and truck block.
however. since i took the oil pan off i know it is a 4 bolt.
other than the dealer that i bought it from telling me that it is a CE engine so far nothing.
the VIN plate on the passenger side right by the front of the cylinder head is blank.
but since it has the propper block stamp saying it is a 72 270 horse 454. why does it matter if it is a CE or junk yard replacement.
You are now saying that the stamp pad is blank, so it's NOT a CE engine.
What ID is on your engine then that allows you to conclude year and HP rating?
Not trying to give you a tough time, just don't understand many of your statements.
