Question. The differences between the 79 and older suspension and the 80-82 suspension, is it more than the differential?
I know there were some measures taken to lighten the 80+ vehicles and am wondering if it is more than the weak aluminum rear.
The crossmember and struts are aluminum as well. Each model year 80, 81 and 82 saw the introduction of more aluminum components until in 82 the monoleaf (fiberglass) was used as well.
So is it a major deal to instal a stronger 79 and earlier rear?
What makes you think the steel rear suspension system is stronger than the alloy? Today, that is all that is used. Are you racing?
Now having said all that the heavy duty FE7 suspension was used when FE7 was ordered during those years when base suspension (rear) was being upgraded to alloy. Once you have all the parts, should bolt right up.
I'm concerned with the differential not the suspension. I know the 7.5" Aluminum Differential is not as strong as the 8.5" Iron Differential. So my real concern is making sure I got a differential that can handle my plan for motor and trans.
I'm curious as to the answers on this too - now that I'm pushing 580 HP in my 80 with new motor & tranny, I wonder if the stock rear will handle it the way I drive it. Fortunately for the rear end, I don't have very sticky tires yet - but that will change soon, and I think once I've got a tire that holds the road that aluminum rear might become the weak link. I'm kind of a "don't fix what isn't broken, but when it breaks fix it right" kind of guy, so I'm curious to know what I should replace it with if and when it does break on me.
1981 is the lightest year C3 corvette, the monoleaf was introduced in 1981.
