dreaded windshild frame rot, suggestions
Old Dec 31, 2008 | 08:33 PM
fuelie65's Avatar
fuelie65
Default dreaded windshild frame rot, suggestions
I'm in the process of restoration on a 70 coupe. Upon removal of the header panel moulding...yup... big holes. The pillars are fine but the corners and about 3" into the header are rotted. I have found the replacement corners and header parts. Has anyone replaced these by just changing out the corners and a few inches of the header panel instead of pulling out the entire section ? the center is fine and it looks like it would be easier to splice into the header and not have to detach the t-top center section from the header and maintain some aligmnent.
Thoughts, experience ...etc.
Old Dec 31, 2008 | 08:41 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
You should do exactly what you are saying. Replace the affected area and leave the rest alone. The damage you are describing shouldnt be a difficult fix.
http://www.2ndgenrestorations.com
Old Dec 31, 2008 | 11:41 PM
RobRace10's Avatar
RobRace10
Here is another thread on that topic.
http://forums.corvetteforum.com/c3-t...al-advice.html
I welded in a cross brace on each corner, cut out the old sections and welded in the new. After your done grind the welds on the cross braces and take them out. I found an air chisel worked very well to separate the seams.
Here is one of my repairs:
Old Jan 1, 2009 | 10:44 AM
70Yellowbird's Avatar
70Yellowbird
To those of you with experience ... after the bad sections are cut out, is anything done to the inside of the pillars to protect the metal from further rusting?
Old Jan 1, 2009 | 11:29 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Great information.
Thanks!
Old Jan 1, 2009 | 10:53 PM
BigBlockTank's Avatar
BigBlockTank
all the above beat me to it. Just as they said, you'll be fine. Just come back and ask if it gets questionable.
Old Jan 1, 2009 | 11:23 PM
RobRace10's Avatar
RobRace10
I believe they rust from the outside in so not sure if that is an issue. I did spray some rust encapsulater into the header and pillar areas that I could get to. I plan on sealing the metal on the outside as well as I can and try to keep the car dry.
Old Jan 2, 2009 | 10:57 AM
fuelie65's Avatar
fuelie65
Default bird cage
Thanks Guys,
I was able to remove the original windshield ( in one piece) and can clearly see it is just the corners. I have them on order and will procede.
Thanks for the help.....i'll be back if all does not go well.
thanks...
Old Jan 2, 2009 | 11:10 AM
MoneyPit's Avatar
MoneyPit
The windshield frame pieces are spot welded each other. Just get your AIM out and determine general locations for the weld. Then if you have access to a sandblaster blast a little to locate the welds on your car. Drill the welds out and use an air hammer or a panel seperation knife and a BFH to seperate the frame. This way you can remove only the pieces you want. Hope that helps.
Old Jan 2, 2009 | 11:39 AM
kydirt's Avatar
kydirt
My corners weren't real bad, so I just ground out all the bad sections, then cut pieces of sheet metal to fit the holes. It takes some time and pretty good welding but it was easier than taking it all apart and getting it all lined up, plus I didn't have to buy the corners.
P.S. don't start your car on fire welding it
To dreaded windshild frame rot, suggestions
