tires
Old Jan 1, 2009 | 08:33 PM
fugawi's Avatar
fugawi
Default tires
what size tire on a 18x9.5 wheel. would like to get close to stock 27 tall .
Old Jan 1, 2009 | 09:10 PM
KTKelly's Avatar
KTKelly
255-45x18 is 27" even.
Old Jan 1, 2009 | 09:58 PM
riggs 74's Avatar
riggs 74
KT, have you got your wheels and tires mounted on the car yet.
I was checking only because I'm just about ready to order mine
and would like to see them on a vett first.
Do you have any photos? Thanks in advance.
Riggs.
Old Jan 1, 2009 | 10:57 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
For future reference...
http://www.rogerkrausracing.com/Tech.../tiredem.shtml
Old Jan 1, 2009 | 11:01 PM
Grumpy 427's Avatar
Grumpy 427
Great link thanks
Old Jan 1, 2009 | 11:29 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
You really need to check the tire manufacturer's specs. Each tire is a little different in tread width, overall diameter, etc.
a 285/40/18 is almost exactly 27" tall and over and inch wider in the tread than a 255/45/18. Unfortunately, it is also about 1.5" wider in the mid section. This is the part that rubs on the frame, etc.
I would personally go with 275/40/18 on the rear and 245/40/18 on the front. This would net a 1" smaller diameter tire, but only affect the speedometer very little. It would give you a little more fender clearance, and still be a very wide tire.
You have to pick a manufacturer that makes both tire sizes for the front and back.
On My Q45, I am running Nitto NT555 245/45/18 on the front and 285/40/18 on the rear. This is probably the perfect sizes for the Vette, but would probably rub on an 18 x 9.5 wheel with a 5" backspacing.
I typically spend a few hours on Tire Rack determining the right size and then find a manufacturer that makes the sizes in the style I like,
To tires
