Another - What is it worth?.....
The frame (straight with nothing other than surface rust)was cleaned and painted with POR15, as all the other chassis parts. All brake and fuel lines are new. The trailing arms themselves are new with rebuilt parts. All calipers were SS lined and rebuilt along with new rotors. All bushings were replaced along with all u-joints. The halfshafts are new as well. Here is a pic of the chassis when I was done:
The engine and the transmission (both original and 350's) were rebuilt by the PO approx. 3 years ago and have very few miles on them since. The rear end patterned ok so I did not rebuild it. The engine has a new Edelebrock manifold, distributor and carb. It has a new CC 2-1-2 Maganflow exhaust with high flow cat and sounds pretty good.
As for the body... it needs some work. I don't have a picture available of it on Phototbucket right now. The 2nd coat of paint has been removed from the majority of it. The bird cage needs some work on the passenger side door frame. There's a hole about the size of a quarter. I did weld in a new driver side floorpan. Other than that it is in good shape. There is still a ton to do to get it where I would want it.
I could never get all the work or parts (headlight assemblies, new heater core, new heater fan, etc) that I have put into it on this thread, but am just trying to get an idea of what I can expect to be offered if i put it up for sale. I will be traveling a lot this year for work and just won't have the time to work on it when I am home. I really hate to sell it, but reality is I probably will never finish it.
Any guesstimate would be appreciated!
If you had a good offer around $5000, I would think it may be a bargain. Maybe a loss for you overall, but still a good deal.
kdf
Thanks for all the input though. I guess I need to figure out if I should let it sit for a year or take a huge loss.
