front clip glue?
Old Jan 5, 2009 | 06:13 PM
glo's Avatar
glo
Default front clip glue?
Getting ready to put the front clip back on my 77, what's a good glue to use?
Old Jan 5, 2009 | 06:16 PM
Fred D. Zwiger's Avatar
Fred D. Zwiger
Default Front End Glue
I use Lord Fusor 21T. It has 45 minute work time and works like a charm.
Fred Z.
Old Jan 5, 2009 | 06:23 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I just used 3m 8219 it is a dual cartridge, worked great.
sets up amazingly well.
but you have to to buy a dispenser gun,
you can buy a "Generic" gun for about $50
69VETT
Old Jan 6, 2009 | 04:25 PM
at3erdbase's Avatar
at3erdbase
Depends
You can go for the high priced Crazy Glue and Elmer's Glue I guess.
Everlast makes a very nice product called Vette Bonding Adhesive. It is your choice of using the blue hardener or using the regular color.. you can get it at you local supply for 24 bucks
Old Jan 7, 2009 | 12:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock '77 panels are SMC. As long as you are using an SMC compatible adhesive, you should be okay.
Old Jan 7, 2009 | 05:43 PM
glo's Avatar
glo
Thanks guys
Old Jan 7, 2009 | 11:03 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Thought most were using 3M's 8115. Good stuff. Works. Lasts. Sets up pretty quickly so make sure your prefits went well prior assy.
To front clip glue?
