Help with Dash lights?
Old Jan 5, 2009 | 06:39 PM
molldog12's Avatar
molldog12
Default Help with Dash lights?
I was driving home tonight and all my dash and shifter lights went out. Does anyone know if all these lights are one fuse? The headlights still work, also the interior light comes on when I turn headlight switch or open the door.
Any help on this problem would be Appreciated.
Thanks, Joe
Old Jan 5, 2009 | 06:44 PM
blk79nj's Avatar
blk79nj
On my car ('79), I think is was the Lighter, dash Lights, Interier Lights, and spare tire light.
I had a dime drop down into the lighter socket and pop the fuse.
Old Jan 5, 2009 | 06:48 PM
molldog12's Avatar
molldog12
I hope that is the problem, I will check it tomorrow.
Old Jan 5, 2009 | 06:49 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Crazy question, but did you check to see if they were dimmed down by the headlight switch? I have done this more than once.
Old Jan 5, 2009 | 06:59 PM
...Roger...'s Avatar
...Roger...
Your dash lights fuse will be labeled INST FUSE...lower left in the fuse box..6 amp..shortest fuse in the box.
Make sure your tailights didnt go also because the tailight fuse feeds the inst fuse.
Old Jan 5, 2009 | 07:00 PM
molldog12's Avatar
molldog12
I checked the headlight switch, I turned it and nothing happened. When I was driving all the lights went out.
Old Jan 5, 2009 | 07:05 PM
400hp427vette
St. Jude Donor '09
I was trying for the easy answer. DWncchs is most likely correct.
molldog12's Avatar
molldog12
I checked the tail lights and they still work.
Old Jan 6, 2009 | 04:01 AM
c3corvettes's Avatar
c3corvettes
Suspect the headlight switch. I remember a thread a while ago that was concerning the dash lights going out. The members really covered it.
Good luck
Old Jan 6, 2009 | 03:45 PM
...Roger...
Usually if the rheostat goes bad you can turn the **** over almost to where the courtesy lights come on and the dash lights will be on max bright. If the inst fuse is not blown put a test light on the inst fuse with the lights on and rotate the **** to see if the fuse is getting power from the headlight switch.
Old Jan 6, 2009 | 04:42 PM
speedbird1229's Avatar
speedbird1229
I recently fixed my instrument lights. One thing that could blow out is the INST FUSE (had it happen twice due to my own errors). When you reach the headlight switch, there is a dark green wire which is supposed to be connected to the aft right jack (aft meaning closest to the rear of car). Check its connection. If that is fine, have a look at the rheostat which is clearly visible when you remove the switch. I believe it could easily break after years of use.
If your fuse was blown, I would check the printed circuit behind the speedo and tach (since you need to remove the block anyway to reach the headlight switch). The circuit seems to catch moisture between its layers and on my 79 one of the wires on it was real bad which rendered the INST fuse blow (I saw sparks from the circuit myself). It's a rather simple job to replace the circuit with a new one and it can be done comfortably on your office desk There is a similar circuit behind the center console gauges but this is harder to reach. I haven't touched it on my Corvette yet.
I'm quite sure one of the possibilities mentioned by me and the others is probably the key. Very unlikely that a wire inside the dash somewhere broke
Old Jan 6, 2009 | 06:57 PM
molldog12's Avatar
molldog12
Thanks for all the replies, I will check everything that all of you suggested. When I find out what the problem was I will reply back.
To Help with Dash lights?
