oil leak
Old Jan 5, 2009 | 08:24 PM
bart man's Avatar
bart man
4th Gear
Default oil leak
I have a oil leak from the bolts on the intake the 4 on bouth sides of the carb [2 per,side] any tips on how too stop this?
Old Jan 5, 2009 | 08:33 PM
dannyman's Avatar
dannyman
Did you just change your intake manifold?
ARP thread sealant.
Old Jan 5, 2009 | 09:11 PM
bart man's Avatar
bart man
4th Gear
I took the intake off to clean and pant. I tried thread tape but no luck. thanks I,ll try it
Old Jan 5, 2009 | 10:18 PM
BigBlockTank's Avatar
BigBlockTank
ARP will work. I've used PermatexAviation Sealant with great results for over 30 years. Your choice, either will work, along with 50 more, I'm sure!!
Old Jan 5, 2009 | 10:19 PM
glen242's Avatar
glen242
Did you use Permatex or ARP sealant on the bolt threads? Without sealant, oil will wick up the bolt threads and leave little puddles on your intake.
To oil leak
